I wanted to ask the Framework team about a bug if they’re not already aware. I’m running Windows 11 on my Framework laptop, using the recommended drivers I downloaded from the Framework website. The touchpad works great, but when I plug in the laptop to charge, it behaves extremely erratically. It lags the motion of my finger. It jumps around, seemingly not in accordance with the motion of my finger. And worst of all, it sometimes emits random clicks, which has resulted in closing windows and hitting buttons that I didn’t mean to.
This is a pretty bad bug, but it only surfaces when the device is plugged in. I’m running the driver installed from:
Framework_Laptop_driver_bundle_2021_12_16.exe
And my OS version is:
Edition Windows 11 Home
Version 21H2
Installed on 4/22/2022
OS build 22000.613
Experience Windows Feature Experience Pack 1000.22000.613.0
This somehow reminds me on a very similar problem some time ago, where I had observed an erratic behaving touchscreen of an iPad and a Fairphone - only when they where charging. This was absolutely reproducible.
No, the charger that came with my laptop broke, so I bought a cheap “compatible” one on Amazon from a random Chinese company and that was pretty terrible.
After that I bought an original OEM USB C charger from Dell, and an Anker one (mainly for travelling and charging my phone/tablet, but also works on the laptop) and those work completely fine.
I’m also experiencing this with windows 10, batch 11, when using a non-framework charger (in my case, a phone charger that happened to be near my desk)
Yeah, this is caused by a bad charger that generates a lot of RF noise. Touchpads are especially sensitive to RFI because of how they work, and if they get overwhelmed with noise they’ll either generate erratic inputs or just not register touches at all.
As a ham I’m sensitive to just how awful some switching power supplies can be in terms of RFI, but a lot of people never notice — until their touchpad stops working.
Possibly. You could also have a lot of electrical noise in your area. I assume the problem doesn’t happen with the charger unplugged (when running on battery)?
You can try charging the laptop with some other charger, e.g. a smartphone charger. Even if that doesn’t charge your laptop sufficiently, you’ll be able to see if that also disturbs the touchpad.
I’m OP and can confirm that the issue resolved by using a better charger. Previously I was using one I had gotten online on Amazon for very cheaply. The Framework charger and another USB-C charger I got for my Macbook both work fine.
I’ll take a look next time I’m back there, but if I remember correctly, the base of the table was metal, while the surface it was actually resting on was not.
I have a decent (albeit slightly outdated) charger, though I’ll note that it’s a travel version, and I’m using the EU plug (which is compatible with ex-soviet outlets, which are what’s used where I live).
