Hi, small but definitely a problem, i have my battery limited to 80% (runnin windows btw newest bios) and it stays at 80% until i power it off. next time i turn it on its at 100% this is new behavior it always worked when i had it limited to 85% but decided to drop to 80%. and now i have to make sure to never leave it plugged in while off. is there something i can do? thanks!
Also, if anyone could tell me how to do something with the led matrix modules because i want to be able to program them instead of using that python script that crashes after using to long.
Just in case anyone else finds this yes, it is an issue with the battery extender because somehow it decides to follow the limit rules while plugged in and it will then charge to 100% and follow whatever rules you had set for the battery life extender. hope this bug gets fixed.
