So is happening again. I just left the laptop on AC reached 98%, now unplugged, I see no sign of discharging.
❯ systemctl status upower
● upower.service - Daemon for power management
Loaded: loaded (/usr/lib/systemd/system/upower.service; disabled; preset: enabled)
Active: active (running) since Mon 2025-04-07 23:39:40 CEST; 1min 59s ago
Docs: man:upowerd(8)
Main PID: 9353 (upowerd)
Tasks: 4 (limit: 74290)
Memory: 4.2M (peak: 5.3M)
CPU: 110ms
CGroup: /system.slice/upower.service
└─9353 /usr/libexec/upowerd
apr 07 23:39:40 jack-framework.16 systemd[1]: Starting upower.service - Daemon for power>
apr 07 23:39:40 jack-framework.16 systemd[1]: Started upower.service - Daemon for power >
lines 1-13/13 (END)
❯ journalctl -u upower
-- Boot cb231adbbb3b46a1ba6a67ed9b5e98b7 --
apr 07 20:24:50 jack-framework.16 systemd[1]: Starting upower.service - Daemon for power>
apr 07 20:24:50 jack-framework.16 systemd[1]: Started upower.service - Daemon for power >
apr 07 22:19:41 jack-framework.16 systemd[1]: Stopping upower.service - Daemon for power>
apr 07 22:19:41 jack-framework.16 systemd[1]: upower.service: Deactivated successfully.
apr 07 22:19:41 jack-framework.16 systemd[1]: Stopped upower.service - Daemon for power >
-- Boot 36a16bb4f84a45c2b0057dae99c4cf41 --
apr 07 23:29:30 jack-framework.16 systemd[1]: Starting upower.service - Daemon for power>
apr 07 23:29:30 jack-framework.16 systemd[1]: Started upower.service - Daemon for power >
apr 07 23:39:40 jack-framework.16 systemd[1]: Stopping upower.service - Daemon for power>
apr 07 23:39:40 jack-framework.16 systemd[1]: upower.service: Deactivated successfully.
apr 07 23:39:40 jack-framework.16 systemd[1]: Stopped upower.service - Daemon for power >
Also notice, those are from charge_now in a span of 10 minutes, I mean those number should go down by the second and it stays the same
❯ cat /sys/class/power_supply/BAT1/charge_now
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
3528000
Also, here is showing state: discharging but the % doesn’t change.
❯ upower -i $(upower -e | grep battery)
native-path: BAT1
vendor: NVT
model: FRANDBA
serial: 00DB
power supply: yes
updated: lun 7 apr 2025, 23:49:58 (30 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 53,9942 Wh
energy-empty: 0 Wh
energy-full: 54,5515 Wh
energy-full-design: 85,0007 Wh
energy-rate: 12,028 W
voltage: 17,017 V
charge-cycles: 104
time to empty: 4,5 hours
percentage: 98%
capacity: 64,1777%
technology: lithium-ion
icon-name: 'battery-full-symbolic'
History (rate):
1744062598 12,028 discharging
1744062597 12,183 discharging
1744062588 14,009 discharging
1744062558 11,858 discharging
1744062528 14,582 discharging
I am really clueless on whats going on.
Thank you for the support!
