I’ve been running into an issue where charging will stop. When I first noticed this it was when I’d left the charger connected as it reached 100%, so I figured it was some firmware shutoff. But today this happened at 70% or so.
Running a 12th-gen DIY that shipped back in August, running Ubuntu Jammy (w/ 5.15.0-60 kernel). At this point I strongly suspect the charger itself is dodgy, but before I shell out for a new one I want to see if folks have other diagnostics I can check.
Things I’ve looked at:
- Unplug the charger from the extension port, and plug it back in (doesn’t work).
- Switch which extension port I’m using (doesn’t work).
- Unplug my charger from the power source and then plug it back in (works!).
- Using a different USB-C charger (works, but it’s not the same power specs so that’s not a permanent solution).
dmesg
/journald
shows nothing when the charger is plugged/unpluggedupower
doesn’t show anything interesting
upower output
$ upower -i /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: NVT
model: Framewo
serial: 00B9
power supply: yes
updated: Sat 11 Feb 2023 03:52:18 PM EST (33 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: charging
warning-level: none
energy: 46.0614 Wh
energy-empty: 0 Wh
energy-full: 55.055 Wh
energy-full-design: 55.0088 Wh
energy-rate: 30.1686 W
voltage: 17.525 V
charge-cycles: 70
time to full: 17.9 minutes
percentage: 83%
capacity: 100%
technology: lithium-ion
icon-name: 'battery-full-charging-symbolic'
History (charge):
1676148738 83.000 charging
History (rate):
1676148738 30.169 charging
1676148675 25.472 charging
Without (3) I’d say “sure, this is just a dodgy charger” but (3) makes me worry there’s some sort of spooky firmware issue here and I’m a little out of my expertise in diagnosing that kind of thing.
