Best external battery for Framework 13
I’m looking to purchase an external battery to recharge my Framework 13 on-the-go. The battery life is just not enough for me and I often find myself without an outlet to plug into.
Can anyone recommend a good, portable external battery that works well with the Framework 13? For example, one that could at least deliver half a charge in a short period of time? Thanks!
David
You should take a look at the Anker 737 external battery. It has PD charge to 140w max and should have enough juice to give you enough power until your day’s off.
