It is great to see the Desktop making full use of the potential of the Ryzen AI Max but given that the APU is reported to yield really decent results also limited power draws, it is a really important question for me if there will be at least any form of option for an eco mode where it is running at less than 120W (maybe 80W or so), even better would be a number of power limit options.
I am thinking of building a fully passively cooled setup and do plan to achieve a cooling performance fit for max power but having some fall back option in case that cooling doesn’t quite cope with that would be great.
I think other threads have already covered the prospect of third-party coolers and stated that it’s very unlikely that there’s anything suitable on the market at this time.
I am not approaching this from the perspective of buying any third party coolers. This is a DIY project of mine, way outside of any warranty of course. I plan on designing my own cooler.
For that it would be good to have options to adjust power consumption limits, if need be.
PS: This is not my first project of that kind. I am writing this from my previous custom passive mod (see here: Reddit - The heart of the internet). But of course, a 28W APU is a much simpler target.
Since I have the Framework Desktop mainboard now I can answer my own question.
There is no option in the bios. However, much better than that. The power management option in the OS is actually really meaningful and offers three very distinct power levels.
Performance: 140W boost for 10 min, 120W sustained Balanced: Very short 115W boost, 100W sustained
Power Save: ~50W (CPU max frequency set to 3GHz)
Important to know: The stock setting is “Balanced”, if you want the advertised 140/120W you need to set it to performance, wherever that power management settings are in your OS. I am very happy with Balanced and those 100W TDP. It is a very nice efficiency/performance gold spot.
Figured I’d resurrect this thread since I’ve done A TON of TDP testing between the 100-140W sustained range on my Max+ 395 64GB variant. Framework’s Strix Halo seems to be the only model without UEFI based power modes and its been really limiting, requiring me to use 3rd party software to get it.
I feel like Framework could make it really simple for us and just give us power profiles, something like what you’re suggesting but also High Performance and Custom. I’d love to be able to give this part a 140W sustained 160W max which has a noticeable performance impact in the SteamOS gaming environment I use this device in.
What I’ve noticed is the chip will hit max boost clocks, 5.1GHz CPU and 2.9GHz GPU at about 135W when using tools in Windows to push it. In SteamOS, I can push it similarly, but only in Desktop Mode, where I’m forced to use SimpleDeckyTDP to get it to at least 120W.
In the game I primarily play, Warframe, keeping the CPU at max boost clock is really important for framerate consistency, something at least SimpleDeckyTDP lets me force, even if I’m ~15W short on sustained TDP.
In case this question comes up, the thermal performance I’ve been able to absolutely maximize using Coolermaster’s new MasterFan A120 that’s all metal and 30mm thick, only ‘requiring’ a custom 3d printed shroud to close the gap, but it really didn’t seem to matter with how close it is to the side panel already. Even at 135W sustained, the CPU/GPU temps are averaging in the high 65-72C range. This is definitely helped by my custom front shroud that maximizes the exhaust airflow as well.
Its made this device hard to recommend for someone potentially looking at even the entry Max 385 32GB model as a Steam Machine alternative, since I’d love to be able to tell them to just go to a High Performance profile, something even the Corsair AI Workstation 300 (that also has 64GB of RAM and a 1TB drive for $1600) has readily available. Someone installing SteamOS is already going into the UEFI to disable Secure Boot, so instructing them to go to a ‘High Performance’ mode wouldn’t be much extra (as well as probably dedicating 16GB of VRAM).
I have, it requires you to use desktop mode to do it which is a whole different environment in SteamOS with different software interactions. Example, HDR without Gamescope just doesn’t work unless you force override it, and that doesn’t always work.
The rest of Strix Halo devices have this feature, its just Framework’s that seems to not have UEFI level options for power profiles/settings. I’d like to see full control personally, including CCD configuration, but that’s a stretch. Having UEFI level Ryzenadj features though would be an expectation for a DIY friendly device.
