Blank Screen on Reboot when Connected to Dock
Fedora Workstation
Which release version?
42
Which kernel are you using?
6.14.2-300.fc42.x86_64 with params amdgpu.dcdebugmask=0x10 (to avoid getting intermittent DE lock-ups)
Vendor: INSYDE Corp. 03.08
Release Date: 03/19/2025
Framework Laptop 13, AMD Ryzen 5 7640U w/ Radeon 760M Graphics
I recently started having this issue where, if I start, or restart, my machine while connected to my CalDigit TS3 Plus Thunderbolt 3 Dock - 85W dock, the machine boots with a blank screen. The keyboard backlights do come on, but the display remains blank no matter how long I wait (if I wait long enough, I also hear fans starting to spin up quite a bit). Ultimately, I have to hard-reset and reboot the machine with the Dock detached.
This issue has been happening consistently, every time I boot or reboot the machine (while connected to the dock). This a new phenomenon as the laptop used to work perfectly with the dock. I’m not sure if the issue is at all related to the BIOS 3.08 (beta) upgrade, or the Fedora 42 upgrade, since I have just returned to using the dock after ~2-3 weeks. For the time being, my workaround is to disconnect from the dock when I need to reboot the machine.
I should probably highlight the fact that when the machine is re/booted when docked, I don’t see anything on the screen; not even the Framework splash screen.
Any ideas as to what might be causing this?
Update 1: Clarified the language, added add’l detail and improved formatting.
Update 2: Highlighted the fact that I don’t even see FW splash screen at boot time.
Ok, so I have concluded that the OS update has nothing to do with the issue described. I have reliably reproduced the issue on the following OSes so far:
  • Ubuntu 24.04
  • Fedora 42
  • Bluefin DX, GTS (based on Fedora Silverblue 41)
It seems this likely has to do with the BIOS update 03.08.
OK, I can now confirm that the issue is 100% related to the BIOS update. I recently upgraded from Ryzen 7640u to 7840u. The 7840u mainboard came with BIOS 3.03. The machine started/restarted perfectly fine while connected to the dock, no issues. However, after I upgraded the BIOS to 3.09 (latest), the laptop now starts with a blank screen when connected to the dock. This is the exact same behavior the 7640u exhibited after I upgraded that board to BIOS 3.08 and later 3.09.
I have opened a ticket with support.
After roughly a month and nearly two-dozen exchanges with support, I was offered the option to escalate the case to engineering. By that time, however, I had already upgraded to Ryzen AI HX 370. Furthermore, I ended up returning the 7840u and repurposed the 7640u in a new chassis, passing it down to a family member.
So, I thanked support and encouraged them to escalate to engineering, but excused myself out of the loop because at this point Framework have all the info they need to reliably reproduce the issue in a lab environment, albeit, they might have to procure some hardware to do so. Given BIOS updates breaking docks or other hardware isn’t that rare, it’d be the right thing to do.
At any rate, I hope Framework will invest more resources into making sure their products not only work by themselves but also with, at least, a small set of well-supported hardware (such as docking stations, external displays, etc.). This is a tall order, but the BIOS situation definitely needs a ton of improvement.
