[FYI] Batch 16 memory channel failure
This just an FYI to document this for any others that might experience the same issue.
Yesterday my laptop started spontaneously rebooting, then it started happening a lot.
I installed memtest86+ and found that if there is a DIMM installed in memory channel 0 then I get non-deterministic failures from 16 to 21GB in the memory map (I have 2x32GB DIMMS).
Installing a DIMM only in channel 1 results in a successful test.
I have been gaming lightly on this laptop (no more than an hour at a time, a few times over the last week) and suspect the thermal stress of gaming has exposed a faulty solder joint on the SoC BGA.
I have opened a ticket with FW support, I just wanted to document this for batch/lot tracking purposes.
