The built in microphone on my new Framework16 is not showing as a device. I have enabled the switch for it and the camera, and the camera works fine but the mic is not seen by the system. It is enabled in the setting/sound/input.
In the bios there is a setting for windows audio and linux audio do you have it set to windows audio?
I don’t know if that effects the mic or just the speakers but it can’t hurt to check.
That was the first thing I checked. Moved the physical switch by the mic back and forth several times and no change. The camera turned on and off by its switch perfectly fine.
I have been in contact with Framework support and completed several troubleshooting steps at their direction. The mic works fine when I plug in my Sennheiser headphones thru the audio adapter module. I have completely removed the mic/camera module and re-installed it with no change.
Framework support is going to RMA the mic/camera module.
They ended up sending me a replacement laptop that had a working microphone. The first attempt was them sending me a new microphone/camera module but after I installed that the mic still did not work. They then agreed to an RMA for the laptop.
I have this same issue. I’m on Windows 11. Yes, I’ve checked the bezel switches many times. External mic works fine. I’m guessing I need a new laptop from Framework like the OP since I don’t see any fixes here. Other topics show a software issue causing mic issues on Linx, but like I said I am on Windows 11.
