Please what is the difference between "Numpad: Numpad Module (for £19.00) " and “Extra Medium Input Module: Numpad Module (for £39.00)” on the order?
The numpad module is $39. The $19 indicates the price difference over the default selection of 2x Black Spacers.
I had the same question and am still confused. When I order, do I have to choose both the “Numpad module” and the “Framework Laptop 16 Numpad”?
you should choose what you need under the “input modules” section. The ones listed under the “Add-ons” section are additional ones (incase you wish to order numpad and spacers, or macropad and led matrix to switch in the future). If you only need one numpad, just choose under “input modules” and ignore the “add-ons” section.
