Question about keyboard IE Numberpad
Looking to purchase a Framework 16; Really disappointed that the 5070ti isn’t available, but I do have a question about the Keyboard (US). Does it come with a number pad? All the unboxing I’ve seen says yes, but I am not sure if it does. No indication on the “Preorder” screen.
The number pad is a separate part that you can add or not to your order.
In order for the system to start up normally, you’ve got to populate (1) keyboard, (1) touchpad and either (1) numpad, (1) macropad or (2) of the half-size LED matrix or spacer modules. So you’ve got to order a keyboard in the language of your choice and additionally one full size or a pair of half size modules to fill the space to the side of the keyboard.
