[closed] Framework 16 Panel
Hi,
Im currently in the process of building my own laptop using a framework 13 mainboard. In order to attach a display Im using the 13 inches edp cable and an adapter. This is kinda jank so Id like to replace that if possible. It appears to me that the 16s cable has the same connector and pinout as the 13 on the motherboard side. Does anyone know the exact panel they are using on the 16 inch and where I can find a datasheet? or at least what connector it uses and its pinout?
https://www.panelook.com/NE160QDM-N63_BOE_16.0_LCM_overview_52209.html
This is the closest I could find. Not a perfect match, but has FreeSync and the specs match with exception to refresh rate.
It seems the actual display isn’t listed on panelook yet, hopefully someone else has better luck!
The exact panel is custom. But it was based on an existing panel. So you probably won’t find the perfect match, just the panel it was based on.
Here is the HWinfo dump for my display.
General Information
Monitor Name: BOE [Unknown Model: BOE0BC9]
Monitor Name (Manuf): BOE CQ NE160QDM-NZ6
Serial Number: Unknown
Date Of Manufacture: Week: 48, Year: 2022
Monitor Hardware ID: Monitor\BOE0BC9
Max. Vertical Size: 22 cm
Max. Horizontal Size: 34 cm
Advanced parameters
Input Signal: Digital
Color Bit Depth: 8 Bits per Primary Color
Digital Video Interface Standard Supported: DisplayPort
Gamma Factor: 2.20
DPMS Modes
Standby: Not Supported
Suspend: Not Supported
Active Off: Not Supported
Standard Colour Space (sRGB) Default: Not Supported
Preferred Timing Mode: Supported
Default GTF (Continuous Frequency): Supported
DFP 1.x Compatible: Yes
Supported Video Modes
2560 x 1600 345 x 215 mm, Pixel Clock 287.24 MHz
Driver Information
Driver Manufacturer: Framework
Driver Description: Framework NE160QDM-NZ6
Driver Provider: Framework
Driver Version: 1.0.0.0
Driver Date: 31-Dec-2023
DeviceInstanceId DISPLAY\BOE0BC9\5&A58B75&0&UID256
Location Paths ACPI(SB)#ACPI(PCI0)#ACPI(GP17)#ACPI(VGA_)#ACPI(LCD_)
Thanks a lot. I wasn’t able to find a datasheet for this panel but now I know what I’m looking for.
