Community developed expansion card appearance
Hi Framework crew,
I think community developed expansion cards that match the appearance of the owner’s laptop would help maintain the professional look of the system. Are you willing to share the materials and surface finishes that your team uses on your cards? Also, do you have any marking requirements/restrictions/recommendations?
Thanks,
Robert
It’s essentially impossible as they use aluminium and small amounts of plastic internally, on small scale manufacture it would be very costly to do aluminium.
Most of these can be done by two-piece (or three-piece) CNC. Plastic can be done via 3D printing (although it make more sense to inject mold, which is very expensive to setup)
Surface finish is like grain-polished and perhaps anodized aluminum (alloy).
Thanks Xavier - I’m also expecting it to be an aluminum alloy that’s blasted with a soft medium and anodized, but just looking for a written confirmation. Some companies are venturing out to other alloys for structural or cosmetic properties. Input from Framework on markings would also be appreciated.
Robert
Josh - While production of enclosures with CNC would add additional costs, some individuals do value the aesthetics/durability of their devices and would be willing to pay the additional material cost. This isn’t true for all users as you suggest, but I know that I would value it.
Robert
The vast majority of the structure can be easily 3D printed or injection molded. To match the exterior though I disagree that CNC milling would be the best solution. You only need the exterior surfaces to the chassis to match, so sheet metal with a single bend is all that’s realistically required. Like another poster above pointed out, all you need at that point is to grit blast, then optionally anodize for durability. For a small business there are companies that do sell custom bent/finished sheet metal for small batch manufacture; as with anything this will have to be balanced with demand.
A well equipped DIYer with printer and laser cutter could realistically handle printing the inner frame in addition to cutting and bending their own exterior sheet metal. Home anodizing for batches is trickier but in my opinion optional for the task of matching the exterior surface finish of the laptop. You’re going to get scratches no matter what, and the little cards are easily replaceable and repairable for a reason.
I disagree that a CNC milled component will ever be competitive with cost compared to a cheap 3-D print. The cost of blank aluminum on its own will be huge, and the majority of the material you’re purchasing will be lost in the chips. For small-scale manufacturing additive mfg with plastics is almost certainly the way to go for something like this. Not least because a CNC milled aluminum block will start doing damage to the laptop’s plastic pins with repeated insertions/removals, as opposed to the hardness-matched plastics.
While I appreciate that there are different methods for fabricating expansion cards with various pros and cons, I would like to keep the discussion on topic. The topic is on expansion card appearance - namely, what materials and treatments are used on the Framework laptop and any advice the Framework team has regarding markings.
Feel free to start another thread discussing fabrication methods if that is of interest. I believe it could be helpful for many future developers.
Thanks,
Robert
