In datasheet Frore claim net 4.25W removed per 1W @ 85C die temperature, 25C ambient. Anyone got resources to compare this power efficiency to conventional fans? compared to @mcz comment, that would suggest comparable efficiency ratios, but with Frore’s chip having lower peak power removal.
I have a pretty standard notebook fan lying around, rated for 3.75W vs Frore’s 1W. I have no idea how much heat a laptop fan removes, would be good to know ballpark in typical operating conditions.
Asides from power/efficiency considerations, as talked about in video the almost unreasonable conduction of vapour chambers could enable crazy conduction of heat via all that copper surface area on their chip, and then a boosted heat transfer coefficient in the convective cooling from a compressed boundary layer! The full heat path once built into a device seems very superior to what is possible with fans.
Since they seem to be working with large OEMs now, it’d be a real shame if their contracts prevented them eventually selling these chips as standardized off the shelf products. At the mention of Apple, recent history isn’t promising and I wouldn’t be surprised if proprietary versions with restricted supply were used by the big manufacturers.
