Better Fan?
In some use cases, a better (quieter/stronger) cooling solution would benefit the framework.
My thought:
Would it be feasible to produce a significantly better fan+heat pipe cooling system (at higher cost), that could be exchange for the current one? As an additional option, like the new hinges?
For me, one of the use cases would be the mini PC.
I was actually wondering about the fan pinouts for me, so I can mount a higher static pressure fan (blower or axial) with a much bigger heatsink on the die itself.
May not be custom tower heatsink but would be great if there’s a fan cable adapter to a PWM fan and a mounting adapter for standard tower coolers.
(I wish for a custom eDP to HDMI/DP board to save a connector when using it in that mode, but that’s off topic).
