CPU Throttling? Clean your vents!
I’ve spent the last two weeks collecting data, designing reproducible test scenarios, and troubleshooting various issues with my Framework 16 such as:
  • CPU throttling down to 544mhz (or other values)
  • Framerate issues in the 1% lows on demanding games
  • PROCHOT flags
  • Performance degradation
  • USB-C PD ports deactivating and becoming unusable until after an ES restart
    • Note: I’m not 100% certain that this has been entirely resolved, but I think I’ve at least definitely mitigated it some. Time will tell.
Turns out, all I had needed to do was clean the vents of my machine, which I had done previously not too long ago. I was so confident that lint/hair build up was not the problem, that I spent tens of hours investigating something that I ultimately resolved with 5 minutes of maintenance. If you’re suffering any of those issues, I urge you to just take the 5 minutes to check, even if you’re “sure they’re clean”. I wouldn’t say I pulled a lot of lint out, but it was more than the 5 hairs I expected. I’d say ~4mm was partially covered, but that was evidently enough to pass a significant thermal threshold.
I am, quite frankly, incredibly embarrassed by this. But, if any of you are suffering the same, I wanted to provide the opportunity to learn from my mistakes.
I’ve repurposed this thread.
Its way too easy to overlook the simpler things. The thing that counts: you figured it out! Hell yeah!
omg thank you! I’ve been investigating for a few days turns out it was all my fault for having clogged up vents!
You saved me so much time and frustration! <3
Sorry to hijack this thread, but does anyone know of a way to force the CPU to throttle based on how hot it gets?
My laptop gets way too hot when I’m using it sometimes, like 130-140⁰F. If I could keep it around 110⁰F max that would be great. I’m on Linux btw and have my power mode set to “Power Saver” and it’s still too much.
Have you tried using the Framework Control program to set a manual fan curve?
I didn’t know about it! Thanks for sharing! Will check it out.
