Loud fan | excessive CPU throttling | laptop running hot? Clean the fan!
My 12th Gen was running slowly, and exhibiting weird CPU throttling and/or excessive fan noise.
I have seen a mix bag of the following:
  • CPU throttled at 400MHz while running heavy loads (like compiling code, or even running s-tui in stress mode)
  • CPU frequency alternating between full speed and 400MHz when under a bit of load
  • fan running at full speed for hours despite the room being fairly cool, and CPU load staying well under 20% for prolonged periods of time
After spending multiple weeks reading this forum and bugging tech support for help, I decided to give my CPU a repaste.
While I was at it, I decided to give the fan assembly a deep clean.
I followed Heatsink and Fan Replacement Guide - Framework Guides and cleaned the fan as best I could by blowing on it and rubbing it with an alcohol soaked cloth (the one that came with the thermal paste kit) to remove the dirt stuck on it.
What I have seen nowhere in the docs is the following:
  • once the fan assembly is disconnected, flip it over, and remove the 3 tiny screws circled in red below
  • carefully remove the tape marked in green
  • pay attention to the clip marked in blue when you lift the fan itself from the heatsink
I found about 1cm3 of lint in there, like the stuff found in laundry dryers! I removed that, and cleaned the heatsink with the same cloth. Blew through the fan outlet like in a harmonica.
Basically, the fan couldn’t really cool things down as half of its exhaust was blocked.
After repasting and reassembling everything, all the annoying symptoms above are gone.
My machine is ~1.5 year old, and I’d tried to clean the fan before, but not to this extent.
@Loell_Framework Since we have exchanged a few emails around this topic but cleaning the fan never came up in support’s suggestions, can I suggest you update relevant docs?
I would also suggest a laptop cleaning guide that includes these steps :slight_smile:
Hope this helps someone!
Great info right here. I was wondering how and if you could get into the fan apparatus to give it a truly thorough clean. Thankfully you showed me how it can be done!
Nice little guide. Just completed similar maintenance on my 11th gen.
But, what are those strange cross-shaped screws? Joking, joking. I’m just not used to seeing the ubiquitous PH screw in Framework products!
With them being a relatively common failure point in otherwise healthy systems, my personal preference would be for the fan to be removeable/replaceable/upgradeable by itself. Though I understand why the tradeoff was made to keep the whole thing as a unit. I wonder what bearings are used, and what kind of MTBFs they have.
That is probably because the fans come completely assembled from some other OEM. Framework would buy them in as a completely assembled item, not assemble them themselves.
