Critical Battery Notification right after unplugging
My battery is at 92% and I keep getting this Crtical Battery Notification, it hasn’t shut off my computer but is just annoying. Anyone know why?
Fedora 42 KDE
Currently using the AMD Ryzen™ AI 7 350
Use $ upower -i $(upower -e | grep battery) and (if installed) $ sudo ectool battery to check the battery health. If the battery is dead, contact support for replacement, if not, the power management is bugged and needs software troubleshooting.
Edit: The problem could also be intermittent connection. (I tested on another laptop with hot-swappable battery)If you remove and reinstall the battery while plugged in, the computer will behave normally until you unplug the AC, then KDE will show 0% but the battery itself isn’t failed.
