False critical battery warning with Fedora
Fedora KDE
Which release version?
42
Which kernel are you using?
6.16.10-200.fc42.x86_64
Which BIOS version are you using?30.03.03
amd ryzen ai 300
Further info:
Suddenly a popup will show critical battery warning 0% → it will jump to like 97% or whatever the real percentage is then. Annoyingly it will also go to sleep mode a few seconds later and I have to wake it up and login again.
This seems to mostly occur shortly after disconnecting my charger?
The problem is the battery. Check that the connector it fitting well and no pins are bent.
If that does not help, maybe there is a bug in the battery bms.
The reason it goes to sleep is because battery below 4% causes the EC to shut the laptop down before it damages the battery. Now in your case the 0% is a false reading, but the EC firmware is not detecting it as false.
Hey, I saw this exactly once a few weeks ago, using Gentoo. I think I was still on 6.16 kernel.
No idea what happened.
If you use KDE you can check the battery’s voltage in Energy — Info Center, in addition to terminal commandupower
If the voltage is around 17V the battery is about 97%. if the battery is only 13~14V the battery is at about 4%
@Eward_Somers
I have the same issue today. Did you ever found a solution?
sorry for the late reply, I updated everything and it went away :confused: so no real help here
By “everything,” what do you mean?
I get a similar error, for me I get the error that the battery is critically low but the percentage never changes. Mine does not go to sleep but it does dim the screen. I do not see a correlation to disconnecting charger.
Fedora 43 Kernel 6.19.8-200.fc43.x86_64
Framework 13 AMD Ryzen AI 5 340 w/ Radeon 840M
yeah so my error was gone for months.. and after a recent fedora update. Back once again.
Was that a kernel update, do you know? Could you pin to an earlier kernel, assuming you can find one that is not problematic?
It vanished again without updates this time.. I really have no idea what exactly is causing it. I am on linux 43 still. No idea if that matters.
