Default Framework Windows 10 Power scheme
I accidentally removed the default power scheme, and replaced it with a generic one. Now options like setting the lid action, and disabling turbo boost are no longer functional. I have to go in and manually change keys in the registry to change things.
Is it possible for me to get the profile again? I don’t know if a mechanism exists for that, so I thought I would ask.
Thanks!
Try powercfg –restoredefaultschemes in the command line
That did the trick. Thanks!
