Delete key not working
Since BIOS update 3.09 (released November 18th, 2025) was installed on my Framework 13 laptop, my delete key has been experiencing intermittent issues. Under Arch Linux and Windows 11, the delete key refuses to work. I have opened the laptop and reseated all ribbon cables and connectors going to the touchpad and motherboard, which temporarily fixes the issue but it eventually returns. I have also discovered that flashing the BIOS again temporarily fixes the issue somehow? I don’t know what’s going on, if it’s Linux causing this issue, or what. I use the delete key frequently in my workflow and not having it working is extremely frustrating. I do not want to pay for a new input cover if I don’t have to.
I’ve been having the same issue recently. Have you found a solution yet by any chance?
Unfortunately no.
I’ve been dealing with this for almost a year now. The problem started without any apparent cause in my case; no recent BIOS updates or noteworthy system changes.
I went back and forth for quite a while with Framework support; there’s a known manufacturing defect on some keyboards with the delete key. It was very strange that the problem arose randomly, though, if it was a physical defect. Unlike OP’s experience, I found that the malfunction was not completely “intermittent”. Rather, it defaulted to not working, but mashing the key A LOT (like 30+ seconds) seemed to temporarily resolve the problem.
After extensive troubleshooting, Framework reluctantly replaced my input cover, and the problem went away… until this week. Now, just as inexplicably as the first time, my delete key has again stopped working. This time, it seems more completely broken: mashing the key sometimes yields ‘delete’, but only very briefly.
My system is Intel Core 12th gen, now firmware version 3.19.
I wondered whether there was some very subtle software problem (I am also on Arch-based linux), and the fact that OP temporarily resolves the problem by flashing the BIOS (?!) would seem to support that.
@fyredragon69 How do you get the BIOS to actually re-flash? My think that when I try to boot to current firmware update media, it just says, “you don’t need to update”.
I also have this since a while on my Framework 13 laptop with Ryzen 7040. Sometimes the delete key works, but mostly not. Never had any issue with any of the other keys. But then, who needs a delete key in the first place :smirking_face:.
Sorry for such a late reply, but I applied the update from Windows 11.
