Dell docking station WD15 K17A on Framework 13 AMD - power delivery issues
I’m using a WD15 K17A on Framework 13 AMD.
It is announced to provide 90W of power delivery.
If i plug it on usb-c (port #1 or #3), everything works but power delivery fluctuates. Sometimes it works, sometimes it does not.
I can’t figure out any determinism yet.
Note: If I also plug the official framework power adpater, charging works
Do someone experience the same problem or have a lead for debugging ?
Best,
I think it’s best to get the EC log while this is going on and reporting it to framework support.
Have you update the BIOS to 3.05? The latest update fixed the PD negotiation problem on some power supplies
Thank you for your concern.
I guess I updated the last bios version.
The bios menu says version : JFP30.03.05
First logs :
juil. 21 11:58:38 nixpos kernel: usb 7-1: new full-speed USB device number 2 using xhci_hcd
juil. 21 11:58:39 nixpos kernel: ucsi_acpi USBC000:00: unknown error 256
juil. 21 11:58:39 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
juil. 21 11:58:40 nixpos kernel: ucsi_acpi USBC000:00: unknown error 256
juil. 21 11:58:40 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
juil. 21 11:58:45 nixpos kernel: xhci_hcd 0000:c3:00.4: Refused to change power state from D0 to D3hot
juil. 21 11:58:45 nixpos kernel: usb 7-1: new full-speed USB device number 3 using xhci_hcd
juil. 21 11:58:46 nixpos kernel: usb 7-1: device descriptor read/64, error -71
juil. 21 11:58:46 nixpos kernel: usb 7-1: new full-speed USB device number 4 using xhci_hcd
juil. 21 11:58:47 nixpos kernel: ucsi_acpi USBC000:00: unknown error 256
juil. 21 11:58:47 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
juil. 21 11:58:50 nixpos kernel: xhci_hcd 0000:c3:00.4: Refused to change power state from D0 to D3hot
juil. 21 11:58:50 nixpos kernel: usb 7-1: new full-speed USB device number 5 using xhci_hcd
juil. 21 11:58:51 nixpos kernel: usb 7-1: device descriptor read/64, error -71
juil. 21 11:58:51 nixpos kernel: usb 7-1: new full-speed USB device number 6 using xhci_hcd
juil. 21 11:58:52 nixpos kernel: ucsi_acpi USBC000:00: unknown error 256
juil. 21 11:58:52 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
juil. 21 11:58:55 nixpos kernel: xhci_hcd 0000:c3:00.4: Refused to change power state from D0 to D3hot
juil. 21 11:58:55 nixpos kernel: usb 7-1: new full-speed USB device number 7 using xhci_hcd
juil. 21 11:58:56 nixpos kernel: usb 7-1: device descriptor read/64, error -71
juil. 21 11:58:56 nixpos kernel: usb 7-1: new full-speed USB device number 8 using xhci_hcd
juil. 21 11:58:57 nixpos kernel: ucsi_acpi USBC000:00: unknown error 256
juil. 21 11:58:57 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
Then I moved the hub and got :
juil. 21 11:58:59 nixpos kernel: usb 8-1: new SuperSpeed USB device number 2 using xhci_hcd
juil. 21 11:58:59 nixpos kernel: usb 8-1: New USB device found, idVendor=0424, idProduct=5807, bcdDevice= 2.04
juil. 21 11:58:59 nixpos kernel: usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
juil. 21 11:58:59 nixpos kernel: usb 8-1: Product: USB5807 Hub
juil. 21 11:58:59 nixpos kernel: usb 8-1: Manufacturer: Microchip
juil. 21 11:58:59 nixpos kernel: hub 8-1:1.0: USB hub found
juil. 21 11:58:59 nixpos kernel: hub 8-1:1.0: 7 ports detected
juil. 21 11:58:59 nixpos boltd[1202]: probing: started [1000]
juil. 21 11:58:59 nixpos kernel: usb 7-1: new full-speed USB device number 9 using xhci_hcd
juil. 21 11:58:59 nixpos kernel: usb 7-1: device descriptor read/64, error -71
juil. 21 11:59:00 nixpos kernel: usb 7-1: new full-speed USB device number 10 using xhci_hcd
juil. 21 11:59:00 nixpos kernel: usb 7-1: device descriptor read/64, error -71
juil. 21 11:59:00 nixpos kernel: usb 8-1: USB disconnect, device number 2
juil. 21 11:59:00 nixpos kernel: usb usb7-port1: attempt power cycle
juil. 21 11:59:00 nixpos kernel: ------------[ cut here ]------------
juil. 21 11:59:00 nixpos kernel: WARNING: CPU: 0 PID: 146 at drivers/gpu/drm/amd/amdgpu/../display/dc/link/protocols/link_dp_capability.c:1532 dp_retrieve_lttpr_cap+0x122/0x1e0 [amdgpu]
juil. 21 11:59:00 nixpos kernel: Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device af_packet nft_chain_nat xt_MASQUERADE nf_conntrack_netlink xfrm_user xfrm_algo xt_addrtype overlay cmac algif_hash algif_skcipher af_alg bnep xt_conntrack snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir ip6t_rpfilter snd_sof_amd_acp ipt_rpfilter snd_sof_pci mt7921e snd_sof_xtensa_dsp mt7921_common snd_sof mt792x_lib mt76_connac_lib snd_sof_utils xt_pkttype snd_pci_ps mt76 snd_amd_sdw_acpi xt_LOG soundwire_amd nf_log_syslog soundwire_generic_allocation xt_tcpudp snd_hda_codec_realtek soundwire_bus nft_compat mac80211 snd_hda_codec_generic snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel btusb hid_sensor_als snd_compress snd_intel_dspcfg btrtl ac97_bus snd_intel_sdw_acpi hid_sensor_trigger btintel snd_pcm_dmaengine industrialio_triggered_buffer kfifo_buf snd_hda_codec snd_rpl_pci_acp6x btbcm hid_sensor_iio_common btmtk snd_acp_pci sch_fq_codel nf_tables mousedev industrialio
juil. 21 11:59:00 nixpos kernel:  snd_hda_core snd_acp_legacy_common edac_mce_amd snd_pci_acp6x cfg80211 joydev bluetooth edac_core snd_hwdep snd_pci_acp5x intel_rapl_msr snd_pcm snd_rn_pci_acp3x sp5100_tco amd_pmf amd_atl nls_iso8859_1 ucsi_acpi amdtee intel_rapl_common snd_acp_config nls_cp437 watchdog crc32_pclmul typec_ucsi amd_sfh snd_timer vfat snd_soc_acpi hid_multitouch polyval_clmulni ecdh_generic hid_sensor_hub fat polyval_generic rfkill gf128mul snd ghash_clmulni_intel ecc framework_laptop(O) typec rapl wmi_bmof k10temp platform_profile soundcore snd_pci_acp3x libarc4 i2c_piix4 roles thermal battery ac tiny_power_button loop i2c_hid_acpi xt_nat i2c_hid button evdev nf_nat mac_hid amd_pmc serio_raw nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter veth tun tap macvlan bridge stp llc kvm_amd ccp kvm cros_ec_lpcs cros_ec fuse configfs efi_pstore nfnetlink dmi_sysfs ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 dm_crypt cbc encrypted_keys trusted asn1_encoder tee hid_generic usbhid hid amdgpu dm_mod dax
juil. 21 11:59:00 nixpos kernel:  nvme input_leds led_class nvme_core atkbd nvme_auth libps2 t10_pi vivaldi_fmap crc32c_intel sha512_ssse3 xhci_pci sha256_ssse3 crc64_rocksoft sha1_ssse3 xhci_pci_renesas crc64 aesni_intel thunderbolt crc_t10dif crypto_simd crct10dif_generic crct10dif_pclmul xhci_hcd cryptd tpm_crb crct10dif_common i8042 rtc_cmos serio tpm_tis tpm_tis_core video wmi backlight amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec gpu_sched drm_suballoc_helper drm_buddy drm_display_helper firmware_class cec efivarfs tpm rng_core autofs4
juil. 21 11:59:00 nixpos kernel: CPU: 0 PID: 146 Comm: kworker/0:1H Tainted: G           O       6.9.5 #1-NixOS
juil. 21 11:59:00 nixpos kernel: Hardware name: Framework Laptop 13 (AMD Ryzen 7040Series)/FRANMDCP05, BIOS 03.05 03/29/2024
juil. 21 11:59:00 nixpos kernel: Workqueue: events_highpri dm_irq_work_func [amdgpu]
juil. 21 11:59:00 nixpos kernel: RIP: 0010:dp_retrieve_lttpr_cap+0x122/0x1e0 [amdgpu]
juil. 21 11:59:00 nixpos kernel: Code: 21 c8 48 c1 e2 38 48 09 d0 48 89 85 98 02 00 00 f6 85 c4 02 00 00 02 74 44 e8 7a ed ff ff 84 c0 75 3b 48 8b 85 d8 01 00 00 90 <0f> 0b 90 c6 85 9c 02 00 00 80 48 8b 40 10 48 8b 30 48 85 f6 74 04
juil. 21 11:59:00 nixpos kernel: RSP: 0018:ffffaa9740513bd8 EFLAGS: 00010246
juil. 21 11:59:00 nixpos kernel: RAX: ffff8c5fcc626300 RBX: 00000000ffffffff RCX: 00ffffffffffffff
juil. 21 11:59:00 nixpos kernel: RDX: 0000000000000007 RSI: ffffaa9740513bd8 RDI: 0000000000000000
juil. 21 11:59:00 nixpos kernel: RBP: ffff8c5fd99b4000 R08: ffff8c5fc3328b20 R09: 0000000000000000
juil. 21 11:59:00 nixpos kernel: R10: 0000000000000000 R11: 0000000000000001 R12: ffff8c5fcc626300
juil. 21 11:59:00 nixpos kernel: R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000000
juil. 21 11:59:00 nixpos kernel: FS:  0000000000000000(0000) GS:ffff8c6641c00000(0000) knlGS:0000000000000000
juil. 21 11:59:00 nixpos kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
juil. 21 11:59:00 nixpos kernel: CR2: 00007fad5c7bed50 CR3: 00000002066ae000 CR4: 0000000000f50ef0
juil. 21 11:59:00 nixpos kernel: PKRU: 55555554
juil. 21 11:59:00 nixpos kernel: Call Trace:
juil. 21 11:59:00 nixpos kernel:  <TASK>
juil. 21 11:59:00 nixpos kernel:  ? __warn+0x80/0x120
juil. 21 11:59:00 nixpos kernel:  ? dp_retrieve_lttpr_cap+0x122/0x1e0 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  ? report_bug+0x164/0x190
juil. 21 11:59:00 nixpos kernel:  ? handle_bug+0x3d/0x80
juil. 21 11:59:00 nixpos kernel:  ? exc_invalid_op+0x17/0x70
juil. 21 11:59:00 nixpos kernel:  ? asm_exc_invalid_op+0x1a/0x20
juil. 21 11:59:00 nixpos kernel:  ? dp_retrieve_lttpr_cap+0x116/0x1e0 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  retrieve_link_cap+0x7b/0xd60 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  ? dal_gpio_close+0x1e/0x30 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  detect_link_and_local_sink+0xdb7/0x11a0 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
juil. 21 11:59:00 nixpos kernel:  link_detect+0x3a/0x500 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  ? dal_gpio_destroy_irq+0x25/0x40 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  ? query_hpd_status+0x6e/0xa0 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  handle_hpd_irq_helper+0xf9/0x170 [amdgpu]
juil. 21 11:59:00 nixpos kernel:  process_one_work+0x18b/0x3b0
juil. 21 11:59:00 nixpos kernel:  worker_thread+0x245/0x350
juil. 21 11:59:00 nixpos kernel:  ? __pfx_worker_thread+0x10/0x10
juil. 21 11:59:00 nixpos kernel:  kthread+0xcd/0x100
juil. 21 11:59:00 nixpos kernel:  ? __pfx_kthread+0x10/0x10
juil. 21 11:59:00 nixpos kernel:  ret_from_fork+0x31/0x50
juil. 21 11:59:00 nixpos kernel:  ret_from_fork_asm+0x1a/0x30
juil. 21 11:59:00 nixpos kernel:  </TASK>
juil. 21 11:59:00 nixpos kernel: ---[ end trace 0000000000000000 ]---
juil. 21 11:59:00 nixpos kernel: usb 7-1: new full-speed USB device number 11 using xhci_hcd
juil. 21 11:59:00 nixpos kernel: usb 7-1: Device not responding to setup address.
juil. 21 11:59:01 nixpos kernel: usb 7-1: Device not responding to setup address.
juil. 21 11:59:01 nixpos kernel: usb 7-1: device not accepting address 11, error -71
juil. 21 11:59:01 nixpos kernel: usb 7-1: WARN: invalid context state for evaluate context command.
juil. 21 11:59:01 nixpos kernel: usb 7-1: new full-speed USB device number 12 using xhci_hcd
juil. 21 11:59:01 nixpos kernel: usb 7-1: device not accepting address 12, error -71
juil. 21 11:59:01 nixpos kernel: usb usb7-port1: unable to enumerate USB device
juil. 21 11:59:02 nixpos kernel: usb 8-1: new SuperSpeed USB device number 3 using xhci_hcd
juil. 21 11:59:02 nixpos kernel: usb 8-1: New USB device found, idVendor=0424, idProduct=5807, bcdDevice= 2.04
juil. 21 11:59:02 nixpos kernel: usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
juil. 21 11:59:02 nixpos kernel: usb 8-1: Product: USB5807 Hub
juil. 21 11:59:02 nixpos kernel: usb 8-1: Manufacturer: Microchip
juil. 21 11:59:02 nixpos kernel: hub 8-1:1.0: USB hub found
juil. 21 11:59:02 nixpos kernel: hub 8-1:1.0: 7 ports detected
juil. 21 11:59:04 nixpos boltd[1202]: probing: timeout, done: [2197068] (2000000)
juil. 21 11:59:19 nixpos kernel: usb 8-1: USB disconnect, device number 3
I suspect the hub to have a “false contact” (sorry for the direct french translation of “faux contact”)
Hi there,
Just got my hands on a new WD15 K17A. Same behaviour.
I plug the dock while the computer is on, on battery. Nothing else is plugged in.
Logs when PD not working :
août 23 10:32:56 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=780000
août 23 10:32:59 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-43 noise=9999 txrate=780000
août 23 10:32:59 nixpos kernel: usb 5-1: new high-speed USB device number 7 using xhci_hcd
août 23 10:32:59 nixpos kernel: usb 5-1: New USB device found, idVendor=0424, idProduct=2807, bcdDevice= 2.04
août 23 10:32:59 nixpos kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:32:59 nixpos kernel: usb 5-1: Product: USB2807 Hub
août 23 10:32:59 nixpos kernel: usb 5-1: Manufacturer: Microchip
août 23 10:32:59 nixpos kernel: hub 5-1:1.0: USB hub found
août 23 10:32:59 nixpos kernel: hub 5-1:1.0: 7 ports detected
août 23 10:32:59 nixpos kernel: [drm] DM_MST: starting TM on aconnector: 000000008de1ff8c [id: 107]
août 23 10:32:59 nixpos kernel: [drm] DM_MST: DP12, 2-lane link detected
août 23 10:32:59 nixpos boltd[1177]: probing: started [1000]
août 23 10:32:59 nixpos kernel: [drm] Downstream port present 1, type 2
août 23 10:32:59 nixpos kernel: usb 6-1: new SuperSpeed USB device number 4 using xhci_hcd
août 23 10:32:59 nixpos kernel: usb 6-1: New USB device found, idVendor=0424, idProduct=5807, bcdDevice= 2.04
août 23 10:32:59 nixpos kernel: usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:32:59 nixpos kernel: usb 6-1: Product: USB5807 Hub
août 23 10:32:59 nixpos kernel: usb 6-1: Manufacturer: Microchip
août 23 10:32:59 nixpos kernel: hub 6-1:1.0: USB hub found
août 23 10:32:59 nixpos kernel: hub 6-1:1.0: 7 ports detected
août 23 10:32:59 nixpos kernel: usb 5-1.1: new high-speed USB device number 8 using xhci_hcd
août 23 10:33:00 nixpos kernel: usb 6-1.2: new SuperSpeed USB device number 5 using xhci_hcd
août 23 10:33:00 nixpos kernel: usb 6-1.2: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.11
août 23 10:33:00 nixpos kernel: usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
août 23 10:33:00 nixpos kernel: usb 6-1.2: Product: USB 10/100/1000 LAN
août 23 10:33:00 nixpos kernel: usb 6-1.2: Manufacturer: Realtek
août 23 10:33:00 nixpos kernel: usb 6-1.2: SerialNumber: 000002000000
août 23 10:33:00 nixpos kernel: r8152-cfgselector 6-1.2: reset SuperSpeed USB device number 5 using xhci_hcd
août 23 10:33:00 nixpos kernel: r8152-cfgselector 6-1.2: Dell TB16 Dock, disable RX aggregation
août 23 10:33:00 nixpos kernel: [drm] Downstream port present 1, type 2
août 23 10:33:00 nixpos kernel: r8152 6-1.2:1.0 eth0: v1.12.13
août 23 10:33:00 nixpos mtp-probe[18745]: checking bus 6, device 5: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2"
août 23 10:33:00 nixpos mtp-probe[18745]: bus: 6, device: 5 was not an MTP device
août 23 10:33:00 nixpos kernel: r8152 6-1.2:1.0 enp195s0f3u1u2: renamed from eth0
août 23 10:33:00 nixpos mtp-probe[18750]: checking bus 6, device 5: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2"
août 23 10:33:00 nixpos kernel: ucsi_acpi USBC000:00: unknown error 0
août 23 10:33:00 nixpos kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
août 23 10:33:00 nixpos mtp-probe[18750]: bus: 6, device: 5 was not an MTP device
août 23 10:33:02 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=780000
août 23 10:33:02 nixpos kernel: usb 5-1.1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
août 23 10:33:02 nixpos kernel: usb 5-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
août 23 10:33:02 nixpos kernel: usb 5-1.1: Product: HD Pro Webcam C920
août 23 10:33:02 nixpos kernel: usb 5-1.1: SerialNumber: DE65D5FF
août 23 10:33:02 nixpos kernel: usb 5-1.1: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
août 23 10:33:02 nixpos boltd[1177]: probing: timeout, done: [2204888] (2000000)
août 23 10:33:02 nixpos mtp-probe[18785]: checking bus 5, device 8: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.1"
août 23 10:33:02 nixpos mtp-probe[18785]: bus: 5, device: 8 was not an MTP device
août 23 10:33:02 nixpos boltd[1177]: probing: started [1000]
août 23 10:33:02 nixpos mtp-probe[18794]: checking bus 5, device 8: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.1"
août 23 10:33:02 nixpos mtp-probe[18794]: bus: 5, device: 8 was not an MTP device
août 23 10:33:02 nixpos wireplumber[1715]: [2:14:49.902550983] [2180]  WARN V4L2 v4l2_pixelformat.cpp:328 Unsupported V4L2 pixel format H264
août 23 10:33:02 nixpos kernel: usb 5-1.5: new high-speed USB device number 9 using xhci_hcd
août 23 10:33:02 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:33:02 nixpos kernel: usb 5-1.5: New USB device found, idVendor=0bda, idProduct=4014, bcdDevice= 0.05
août 23 10:33:02 nixpos kernel: usb 5-1.5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
août 23 10:33:02 nixpos kernel: usb 5-1.5: Product: USB Audio
août 23 10:33:02 nixpos kernel: usb 5-1.5: Manufacturer: Generic
août 23 10:33:02 nixpos kernel: usb 5-1.5: SerialNumber: 200901010001
août 23 10:33:03 nixpos kernel: r8152 6-1.2:1.0 enp195s0f3u1u2: carrier on
août 23 10:33:03 nixpos systemd[1]: Stopped target Host and Network Name Lookups.
août 23 10:33:03 nixpos systemd[1]: Stopping Host and Network Name Lookups...
août 23 10:33:03 nixpos systemd[1]: Stopped target User and Group Name Lookups.
août 23 10:33:03 nixpos systemd[1]: Stopping User and Group Name Lookups...
août 23 10:33:03 nixpos systemd[1]: Stopping Name Service Cache Daemon (nsncd)...
août 23 10:33:03 nixpos systemd[1]: nscd.service: Deactivated successfully.
août 23 10:33:03 nixpos systemd[1]: Stopped Name Service Cache Daemon (nsncd).
août 23 10:33:03 nixpos systemd[1]: nscd.service: Consumed 303ms CPU time, received 67.9K IP traffic, sent 38.7K IP traffic.
août 23 10:33:03 nixpos avahi-daemon[1174]: Got SIGHUP, reloading.
août 23 10:33:03 nixpos avahi-daemon[1174]: No service file found in /etc/avahi/services.
août 23 10:33:03 nixpos avahi-daemon[1174]: Joining mDNS multicast group on interface enp195s0f3u1u2.IPv4 with address 192.168.1.25.
août 23 10:33:03 nixpos avahi-daemon[1174]: New relevant interface enp195s0f3u1u2.IPv4 for mDNS.
août 23 10:33:03 nixpos dbus-daemon[1178]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1351 comm="/nix/store/s244czqxs4v9d168mzgna9r713qw86m7-networ" label="kernel")
août 23 10:33:03 nixpos systemd[1]: Starting Name Service Cache Daemon (nsncd)...
août 23 10:33:03 nixpos systemd[1]: Starting Network Manager Script Dispatcher Service...
août 23 10:33:03 nixpos nsncd[18846]: Aug 23 08:33:03.484 INFO started, config: Config { ignored_request_types: {}, worker_count: 8, handoff_timeout: 3s }, path: "/var/run/nscd/socket"
août 23 10:33:03 nixpos systemd[1]: Started Name Service Cache Daemon (nsncd).
août 23 10:33:03 nixpos systemd[1]: Reached target Host and Network Name Lookups.
août 23 10:33:03 nixpos systemd[1]: Reached target User and Group Name Lookups.
août 23 10:33:03 nixpos dbus-daemon[1178]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
août 23 10:33:03 nixpos systemd[1]: Started Network Manager Script Dispatcher Service.
août 23 10:33:04 nixpos mtp-probe[18871]: checking bus 5, device 9: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.5"
août 23 10:33:04 nixpos mtp-probe[18871]: bus: 5, device: 9 was not an MTP device
août 23 10:33:04 nixpos mtp-probe[18874]: checking bus 5, device 9: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.5"
août 23 10:33:04 nixpos mtp-probe[18874]: bus: 5, device: 9 was not an MTP device
août 23 10:33:04 nixpos kernel: usb 5-1.6: new full-speed USB device number 10 using xhci_hcd
août 23 10:33:04 nixpos kernel: usb 5-1.6: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.40
août 23 10:33:04 nixpos kernel: usb 5-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:33:04 nixpos kernel: usb 5-1.6: Product: 2.4G Receiver
août 23 10:33:04 nixpos kernel: usb 5-1.6: Manufacturer: Compx
août 23 10:33:04 nixpos ModemManager[16804]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2': not supported by any plugin
août 23 10:33:04 nixpos gnome-keyring-daemon[1490]: asked to register item /org/freedesktop/secrets/collection/login/14, but it's already registered
août 23 10:33:04 nixpos systemd[1]: Stopped target Host and Network Name Lookups.
août 23 10:33:04 nixpos systemd[1]: Stopping Host and Network Name Lookups...
août 23 10:33:04 nixpos systemd[1]: Stopped target User and Group Name Lookups.
août 23 10:33:04 nixpos systemd[1]: Stopping User and Group Name Lookups...
août 23 10:33:04 nixpos systemd[1]: Stopping Name Service Cache Daemon (nsncd)...
août 23 10:33:04 nixpos systemd[1]: nscd.service: Deactivated successfully.
août 23 10:33:04 nixpos systemd[1]: Stopped Name Service Cache Daemon (nsncd).
août 23 10:33:04 nixpos avahi-daemon[1174]: Got SIGHUP, reloading.
août 23 10:33:04 nixpos avahi-daemon[1174]: No service file found in /etc/avahi/services.
août 23 10:33:04 nixpos systemd[1]: Starting Name Service Cache Daemon (nsncd)...
août 23 10:33:04 nixpos nsncd[18926]: Aug 23 08:33:04.709 INFO started, config: Config { ignored_request_types: {}, worker_count: 8, handoff_timeout: 3s }, path: "/var/run/nscd/socket"
août 23 10:33:04 nixpos systemd[1]: Started Name Service Cache Daemon (nsncd).
août 23 10:33:04 nixpos systemd[1]: Reached target Host and Network Name Lookups.
août 23 10:33:04 nixpos systemd[1]: Reached target User and Group Name Lookups.
août 23 10:33:04 nixpos kernel: input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.0/0003:25A7:FA23.000B/input/input27
août 23 10:33:04 nixpos kernel: hid-generic 0003:25A7:FA23.000B: input,hidraw1: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:c3:00.3-1.6/input0
août 23 10:33:04 nixpos kernel: input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000C/input/input28
août 23 10:33:04 nixpos kernel: input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000C/input/input29
août 23 10:33:04 nixpos kernel: input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000C/input/input30
août 23 10:33:05 nixpos kernel: input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000C/input/input31
août 23 10:33:05 nixpos kernel: hid-generic 0003:25A7:FA23.000C: input,hiddev97,hidraw2: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:c3:00.3-1.6/input1
août 23 10:33:05 nixpos mtp-probe[18950]: checking bus 5, device 10: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6"
août 23 10:33:05 nixpos mtp-probe[18950]: bus: 5, device: 10 was not an MTP device
août 23 10:33:05 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event5 (Compx 2.4G Receiver Consumer Control)
août 23 10:33:05 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event2 (Compx 2.4G Receiver)
août 23 10:33:05 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event6 (Compx 2.4G Receiver System Control)
août 23 10:33:05 nixpos mtp-probe[18962]: checking bus 5, device 10: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6"
août 23 10:33:05 nixpos mtp-probe[18962]: bus: 5, device: 10 was not an MTP device
août 23 10:33:05 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=780000
août 23 10:33:07 nixpos boltd[1177]: probing: timeout, done: [2673136] (2000000)
août 23 10:33:08 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=780000
août 23 10:33:08 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:33:10 nixpos gnome-keyring-daemon[1490]: asked to register item /org/freedesktop/secrets/collection/login/13, but it's already registered
août 23 10:33:11 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=780000
août 23 10:33:12 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:33:13 nixpos systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
août 23 10:33:14 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=780000
août 23 10:33:17 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-45 noise=9999 txrate=87800
août 23 10:33:20 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=585000
août 23 10:33:23 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=780000
août 23 10:33:24 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:33:26 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=780000
Logs when PD working :
août 23 10:35:50 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=780000
août 23 10:35:53 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-49 noise=9999 txrate=468000
août 23 10:35:55 nixpos systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
août 23 10:35:56 nixpos kernel: usb 5-1: new high-speed USB device number 11 using xhci_hcd
août 23 10:35:56 nixpos kernel: usb 5-1: New USB device found, idVendor=0424, idProduct=2807, bcdDevice= 2.04
août 23 10:35:56 nixpos kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:35:56 nixpos kernel: usb 5-1: Product: USB2807 Hub
août 23 10:35:56 nixpos kernel: usb 5-1: Manufacturer: Microchip
août 23 10:35:56 nixpos kernel: hub 5-1:1.0: USB hub found
août 23 10:35:56 nixpos kernel: hub 5-1:1.0: 7 ports detected
août 23 10:35:56 nixpos boltd[1177]: probing: started [1000]
août 23 10:35:56 nixpos kernel: usb 5-1.1: new high-speed USB device number 12 using xhci_hcd
août 23 10:35:56 nixpos kernel: ucsi_acpi USBC000:00: unknown error 0
août 23 10:35:56 nixpos kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
août 23 10:35:56 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-49 noise=9999 txrate=468000
août 23 10:35:56 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:35:57 nixpos kernel: [drm] DM_MST: starting TM on aconnector: 000000008de1ff8c [id: 107]
août 23 10:35:57 nixpos kernel: [drm] DM_MST: DP12, 2-lane link detected
août 23 10:35:57 nixpos kernel: [drm] Downstream port present 1, type 2
août 23 10:35:58 nixpos kernel: usb 6-1: new SuperSpeed USB device number 6 using xhci_hcd
août 23 10:35:58 nixpos kernel: usb 6-1: New USB device found, idVendor=0424, idProduct=5807, bcdDevice= 2.04
août 23 10:35:58 nixpos kernel: usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:35:58 nixpos kernel: usb 6-1: Product: USB5807 Hub
août 23 10:35:58 nixpos kernel: usb 6-1: Manufacturer: Microchip
août 23 10:35:58 nixpos kernel: hub 6-1:1.0: USB hub found
août 23 10:35:58 nixpos kernel: hub 6-1:1.0: 7 ports detected
août 23 10:35:58 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:35:58 nixpos kernel: usb 5-1.1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
août 23 10:35:58 nixpos kernel: usb 5-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
août 23 10:35:58 nixpos kernel: usb 5-1.1: Product: HD Pro Webcam C920
août 23 10:35:58 nixpos kernel: usb 5-1.1: SerialNumber: DE65D5FF
août 23 10:35:59 nixpos kernel: usb 6-1.2: new SuperSpeed USB device number 7 using xhci_hcd
août 23 10:35:59 nixpos kernel: usb 5-1.1: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
août 23 10:35:59 nixpos kernel: usb 6-1.2: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.11
août 23 10:35:59 nixpos kernel: usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
août 23 10:35:59 nixpos kernel: usb 6-1.2: Product: USB 10/100/1000 LAN
août 23 10:35:59 nixpos kernel: usb 6-1.2: Manufacturer: Realtek
août 23 10:35:59 nixpos kernel: usb 6-1.2: SerialNumber: 000002000000
août 23 10:35:59 nixpos kernel: r8152-cfgselector 6-1.2: reset SuperSpeed USB device number 7 using xhci_hcd
août 23 10:35:59 nixpos kernel: r8152-cfgselector 6-1.2: Dell TB16 Dock, disable RX aggregation
août 23 10:35:59 nixpos kernel: r8152 6-1.2:1.0 eth0: v1.12.13
août 23 10:35:59 nixpos mtp-probe[19594]: checking bus 5, device 12: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.1"
août 23 10:35:59 nixpos mtp-probe[19595]: checking bus 6, device 7: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2"
août 23 10:35:59 nixpos mtp-probe[19594]: bus: 5, device: 12 was not an MTP device
août 23 10:35:59 nixpos mtp-probe[19595]: bus: 6, device: 7 was not an MTP device
août 23 10:35:59 nixpos mtp-probe[19606]: checking bus 5, device 12: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.1"
août 23 10:35:59 nixpos mtp-probe[19606]: bus: 5, device: 12 was not an MTP device
août 23 10:35:59 nixpos kernel: r8152 6-1.2:1.0 enp195s0f3u1u2: renamed from eth0
août 23 10:35:59 nixpos mtp-probe[19609]: checking bus 6, device 7: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2"
août 23 10:35:59 nixpos wireplumber[1715]: [2:17:46.572237285] [2180]  WARN V4L2 v4l2_pixelformat.cpp:328 Unsupported V4L2 pixel format H264
août 23 10:35:59 nixpos mtp-probe[19609]: bus: 6, device: 7 was not an MTP device
août 23 10:35:59 nixpos kernel: usb 5-1.5: new high-speed USB device number 13 using xhci_hcd
août 23 10:35:59 nixpos kernel: usb 5-1.5: New USB device found, idVendor=0bda, idProduct=4014, bcdDevice= 0.05
août 23 10:35:59 nixpos kernel: usb 5-1.5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
août 23 10:35:59 nixpos kernel: usb 5-1.5: Product: USB Audio
août 23 10:35:59 nixpos kernel: usb 5-1.5: Manufacturer: Generic
août 23 10:35:59 nixpos kernel: usb 5-1.5: SerialNumber: 200901010001
août 23 10:35:59 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=780000
août 23 10:36:00 nixpos mtp-probe[19615]: checking bus 5, device 13: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.5"
août 23 10:36:00 nixpos mtp-probe[19615]: bus: 5, device: 13 was not an MTP device
août 23 10:36:00 nixpos mtp-probe[19617]: checking bus 5, device 13: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.5"
août 23 10:36:00 nixpos mtp-probe[19617]: bus: 5, device: 13 was not an MTP device
août 23 10:36:00 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:36:00 nixpos kernel: usb 5-1.6: new full-speed USB device number 14 using xhci_hcd
août 23 10:36:00 nixpos kernel: usb 5-1.6: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.40
août 23 10:36:00 nixpos kernel: usb 5-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
août 23 10:36:00 nixpos kernel: usb 5-1.6: Product: 2.4G Receiver
août 23 10:36:00 nixpos kernel: usb 5-1.6: Manufacturer: Compx
août 23 10:36:01 nixpos kernel: input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.0/0003:25A7:FA23.000D/input/input33
août 23 10:36:01 nixpos kernel: hid-generic 0003:25A7:FA23.000D: input,hidraw1: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:c3:00.3-1.6/input0
août 23 10:36:01 nixpos kernel: input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000E/input/input34
août 23 10:36:01 nixpos kernel: input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000E/input/input35
août 23 10:36:01 nixpos kernel: input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000E/input/input36
août 23 10:36:01 nixpos kernel: input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6/5-1.6:1.1/0003:25A7:FA23.000E/input/input37
août 23 10:36:01 nixpos kernel: hid-generic 0003:25A7:FA23.000E: input,hiddev97,hidraw2: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:c3:00.3-1.6/input1
août 23 10:36:01 nixpos mtp-probe[19618]: checking bus 5, device 14: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6"
août 23 10:36:01 nixpos mtp-probe[19618]: bus: 5, device: 14 was not an MTP device
août 23 10:36:01 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event2 (Compx 2.4G Receiver)
août 23 10:36:01 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event6 (Compx 2.4G Receiver System Control)
août 23 10:36:01 nixpos systemd-logind[1233]: Watching system buttons on /dev/input/event5 (Compx 2.4G Receiver Consumer Control)
août 23 10:36:01 nixpos mtp-probe[19638]: checking bus 5, device 14: "/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1.6"
août 23 10:36:01 nixpos mtp-probe[19638]: bus: 5, device: 14 was not an MTP device
août 23 10:36:02 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
août 23 10:36:02 nixpos wpa_supplicant[16848]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=780000
août 23 10:36:02 nixpos kernel: r8152 6-1.2:1.0 enp195s0f3u1u2: carrier on
août 23 10:36:03 nixpos systemd[1]: Stopped target Host and Network Name Lookups.
août 23 10:36:03 nixpos systemd[1]: Stopping Host and Network Name Lookups...
août 23 10:36:03 nixpos systemd[1]: Stopped target User and Group Name Lookups.
août 23 10:36:03 nixpos systemd[1]: Stopping User and Group Name Lookups...
août 23 10:36:03 nixpos systemd[1]: Stopping Name Service Cache Daemon (nsncd)...
août 23 10:36:03 nixpos systemd[1]: nscd.service: Deactivated successfully.
août 23 10:36:03 nixpos systemd[1]: Stopped Name Service Cache Daemon (nsncd).
août 23 10:36:03 nixpos systemd[1]: nscd.service: Consumed 82ms CPU time, received 618B IP traffic, sent 798B IP traffic.
août 23 10:36:03 nixpos avahi-daemon[1174]: Got SIGHUP, reloading.
août 23 10:36:03 nixpos avahi-daemon[1174]: No service file found in /etc/avahi/services.
août 23 10:36:03 nixpos avahi-daemon[1174]: Joining mDNS multicast group on interface enp195s0f3u1u2.IPv4 with address 192.168.1.25.
août 23 10:36:03 nixpos avahi-daemon[1174]: New relevant interface enp195s0f3u1u2.IPv4 for mDNS.
août 23 10:36:03 nixpos dbus-daemon[1178]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=1351 comm="/nix/store/s244czqxs4v9d168mzgna9r713qw86m7-networ" label="kernel")
août 23 10:36:03 nixpos systemd[1]: Starting Name Service Cache Daemon (nsncd)...
août 23 10:36:03 nixpos systemd[1]: Starting Network Manager Script Dispatcher Service...
août 23 10:36:03 nixpos nsncd[19693]: Aug 23 08:36:03.065 INFO started, config: Config { ignored_request_types: {}, worker_count: 8, handoff_timeout: 3s }, path: "/var/run/nscd/socket"
août 23 10:36:03 nixpos systemd[1]: Started Name Service Cache Daemon (nsncd).
août 23 10:36:03 nixpos systemd[1]: Reached target Host and Network Name Lookups.
août 23 10:36:03 nixpos systemd[1]: Reached target User and Group Name Lookups.
août 23 10:36:03 nixpos dbus-daemon[1178]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
août 23 10:36:03 nixpos systemd[1]: Started Network Manager Script Dispatcher Service.
août 23 10:36:03 nixpos ModemManager[16804]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb6/6-1/6-1.2': not supported by any plugin
août 23 10:36:04 nixpos boltd[1177]: probing: timeout, done: [2567091] (2000000)
août 23 10:36:04 nixpos systemd[1]: Stopped target Host and Network Name Lookups.
août 23 10:36:04 nixpos systemd[1]: Stopping Host and Network Name Lookups...
août 23 10:36:04 nixpos systemd[1]: Stopped target User and Group Name Lookups.
août 23 10:36:04 nixpos systemd[1]: Stopping User and Group Name Lookups...
août 23 10:36:04 nixpos systemd[1]: Stopping Name Service Cache Daemon (nsncd)...
août 23 10:36:04 nixpos systemd[1]: nscd.service: Deactivated successfully.
août 23 10:36:04 nixpos systemd[1]: Stopped Name Service Cache Daemon (nsncd).
août 23 10:36:04 nixpos avahi-daemon[1174]: Got SIGHUP, reloading.
août 23 10:36:04 nixpos avahi-daemon[1174]: No service file found in /etc/avahi/services.
août 23 10:36:04 nixpos systemd[1]: Starting Name Service Cache Daemon (nsncd)...
août 23 10:36:04 nixpos nsncd[19766]: Aug 23 08:36:04.436 INFO started, config: Config { ignored_request_types: {}, worker_count: 8, handoff_timeout: 3s }, path: "/var/run/nscd/socket"
août 23 10:36:04 nixpos systemd[1]: Started Name Service Cache Daemon (nsncd).
août 23 10:36:04 nixpos systemd[1]: Reached target Host and Network Name Lookups.
août 23 10:36:04 nixpos systemd[1]: Reached target User and Group Name Lookups.
août 23 10:36:04 nixpos kernel: xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
After few tries, I think I found a pattern.
First time I plug it, everything works (screens, usb, network) excepts power delivery, if I unplugg then replug, everything works including PD
Hi, bit of a necropost but just wanting to say I also have similar issues with a WD15 + fw13 with 7640u mainboard. I’m not sure if it’s the same pattern as you, but I’ve definitely noticed that it’ll start charging as soon as I plug it in, but sometimes just stops charging in the middle of usage (and does not resume charging, it’ll drain battery to zero, i.e. it’s not just the BIOS setting for keeping the battery around 65 - 70%). I have to unplug the power supply going into the dock in order for it to start charging again. This is on the bottom right usbc port. No issues with framework charger, nor with a dell WD19 dock at work.
I’ll check to see if unplugging + plugging in again works like you said.
I have a similar problem with my framework 13 (AI 350, gentoo, kernel 6.15.9) and a WD15. Often the dock won’t charge the laptop. I think it is connected to the buggy suspend and power issues of the framework 13: if I resume from a suspend and plug it in, it often won’t charge. Sometimes unplugging/replugging will fix it, sometimes not. Shutting down and restarting the laptop will restore charging. Note that when it is not charging from the dock, the ethernet from the dock through the usb-C still works.
