Hello,
My Framework Laptop running Windows 10 has been experiencing very noticeable performance (lagging/stuttering) issues lately. The microstutters are very regular (every 1 secord). I tried updating/reinstalling drivers and rebooting etc., to no avail.
However, I came across a topic on this forum attributing the stuttering to the DP Expansion Card. After removing the card, I immediately saw a world of difference, and everything ran incredibly smoothly right away, even without a reboot. I plugged and removed it a few times in a few different ports just to confirm, and I am now certain that this stutter is caused due to this expansion card regardless of which port it’s plugged into.
Do I have a faulty card? What can I do to fix this? I should mention that this is a work laptop I received and as such I don’t have access to any order/batch information currently, but I believe it is a DIY edition and it’s running 11th gen intel. I also don’t have the tools to open up the laptop, so I was very hoping I could fix this issue via some software adjustments. I am currently just running the laptop without the card plugged in (as I don’t require it), but it is very awkward using the laptop with a hole where the card sits.
Could I somehow plug it in and disable it on Windows? How can I disable that USB-C port entirely? Is there a way to disable expansion cards?
Any insights would be appreciated,
Cheers!
