I’ve been trying to connect my Dell U2515H monitor using DP expansion card.
Win11: if monitor connects it works flawlessly up until laptop goes to sleep. After that expansion card not detected and once per few seconds OS sends “bleep” sounds (device connected) but nothing happens. I couldn’t find a reliable way to restore the connection. Reboot, remove card, reconnect cable, change slot, change input source on monitor - nothing works in 100% cases.
Fedora 35: expansion card detected only without cable attached. As soon as I attach the DP cable - expansion card disconnects (dmesg logs attached bellow)
For both OS: if I choose HDMI input (not connected) OS detect the monitor and starts using it. As soon as I change input back to DP - disconnects.
Short video of the problem
dmesg logs
Jan 19 12:39:57 piccolo kernel: usb 3-3: new full-speed USB device number 70 using xhci_hcd
Jan 19 12:39:57 piccolo kernel: usb 3-3: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:39:57 piccolo kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:39:57 piccolo kernel: usb 3-3: Product: DisplayPort Expansion Card
Jan 19 12:39:57 piccolo kernel: usb 3-3: Manufacturer: Framework
Jan 19 12:39:57 piccolo kernel: usb 3-3: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:39:57 piccolo kernel: hid-generic 0003:32AC:0003.0033: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-3/input1
Jan 19 12:40:03 piccolo kernel: usb 3-3: USB disconnect, device number 70
Jan 19 12:40:08 piccolo kernel: usb 3-3: new full-speed USB device number 71 using xhci_hcd
Jan 19 12:40:08 piccolo kernel: usb 3-3: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:08 piccolo kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:08 piccolo kernel: usb 3-3: Product: DisplayPort Expansion Card
Jan 19 12:40:08 piccolo kernel: usb 3-3: Manufacturer: Framework
Jan 19 12:40:08 piccolo kernel: usb 3-3: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:08 piccolo kernel: usb 3-3: can't set config #1, error -71
Jan 19 12:40:08 piccolo kernel: usb 3-3: USB disconnect, device number 71
Jan 19 12:40:09 piccolo kernel: i915 0000:00:02.0: [drm] *ERROR* Sending link address failed with -5
Jan 19 12:40:11 piccolo kernel: usb 3-3: new full-speed USB device number 72 using xhci_hcd
Jan 19 12:40:11 piccolo kernel: usb 3-3: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:11 piccolo kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:11 piccolo kernel: usb 3-3: Product: DisplayPort Expansion Card
Jan 19 12:40:11 piccolo kernel: usb 3-3: Manufacturer: Framework
Jan 19 12:40:11 piccolo kernel: usb 3-3: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:11 piccolo kernel: usbhid 3-3:1.1: can't add hid device: -71
Jan 19 12:40:11 piccolo kernel: usbhid: probe of 3-3:1.1 failed with error -71
Jan 19 12:40:11 piccolo kernel: usb 3-3: USB disconnect, device number 72
Jan 19 12:40:16 piccolo kernel: usb 3-3: new full-speed USB device number 73 using xhci_hcd
Jan 19 12:40:24 piccolo kernel: usb 3-1: new full-speed USB device number 74 using xhci_hcd
Jan 19 12:40:24 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:24 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:24 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:40:24 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:40:24 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:24 piccolo kernel: hid-generic 0003:32AC:0003.0034: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:40:29 piccolo kernel: usb 3-1: USB disconnect, device number 74
Jan 19 12:40:31 piccolo kernel: usb 3-1: new full-speed USB device number 75 using xhci_hcd
Jan 19 12:40:31 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:31 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:31 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:40:31 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:40:31 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:31 piccolo kernel: hid-generic 0003:32AC:0003.0035: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:40:32 piccolo kernel: usb 3-1: USB disconnect, device number 75
Jan 19 12:40:36 piccolo kernel: i915 0000:00:02.0: [drm] *ERROR* Sending link address failed with -5
Jan 19 12:40:39 piccolo kernel: usb 3-1: new full-speed USB device number 76 using xhci_hcd
Jan 19 12:40:40 piccolo kernel: usb 3-1: Device not responding to setup address.
Jan 19 12:40:40 piccolo kernel: usb 3-1: device not accepting address 76, error -71
Jan 19 12:40:42 piccolo kernel: usb 3-1: new full-speed USB device number 78 using xhci_hcd
Jan 19 12:40:45 piccolo kernel: usb 3-1: new full-speed USB device number 79 using xhci_hcd
Jan 19 12:40:45 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:45 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:45 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:40:45 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:40:45 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:45 piccolo kernel: hid-generic 0003:32AC:0003.0036: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:40:48 piccolo kernel: usb 3-1: USB disconnect, device number 79
Jan 19 12:40:51 piccolo kernel: usb 3-1: new full-speed USB device number 80 using xhci_hcd
Jan 19 12:40:51 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:51 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:51 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:40:51 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:40:51 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:51 piccolo kernel: hid-generic 0003:32AC:0003.0037: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:40:55 piccolo kernel: usb 3-1: USB disconnect, device number 80
Jan 19 12:40:58 piccolo kernel: usb 3-1: new full-speed USB device number 81 using xhci_hcd
Jan 19 12:40:58 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:40:58 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:40:58 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:40:58 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:40:58 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:40:58 piccolo kernel: hid-generic 0003:32AC:0003.0038: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:41:02 piccolo kernel: usb 3-1: USB disconnect, device number 81
Jan 19 12:41:11 piccolo kernel: i915 0000:00:02.0: [drm] *ERROR* Sending link address failed with -5
Jan 19 12:41:12 piccolo kernel: usb 3-1: new full-speed USB device number 82 using xhci_hcd
Jan 19 12:41:12 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:41:12 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:41:12 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:41:12 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:41:12 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:41:12 piccolo kernel: hid-generic 0003:32AC:0003.0039: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:41:12 piccolo kernel: usb 3-1: USB disconnect, device number 82
Jan 19 12:41:15 piccolo kernel: usb 3-1: new full-speed USB device number 83 using xhci_hcd
Jan 19 12:41:15 piccolo kernel: usb 3-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
Jan 19 12:41:15 piccolo kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 19 12:41:15 piccolo kernel: usb 3-1: Product: DisplayPort Expansion Card
Jan 19 12:41:15 piccolo kernel: usb 3-1: Manufacturer: Framework
Jan 19 12:41:15 piccolo kernel: usb 3-1: SerialNumber: 11AD1D00F48A2E0D23240B00
Jan 19 12:41:15 piccolo kernel: hid-generic 0003:32AC:0003.003A: hiddev96,hidraw3: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:00:14.0-1/input1
Jan 19 12:41:15 piccolo kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read DPCD register 0x92
Jan 19 13:01:28 piccolo kernel: usb 3-9: reset full-speed USB device number 3 using xhci_hcd
