I managed to make my own enclosure, using off the shelf parts from amazon. it uses DisplayPort and requires usbc power.
Total cost 30$ not including double sided tape and electrical tape.
8.5x12 inch picture frame
Amazon.com - JCJMY 8.5x12 Picture Frame Gold for Wall Hanging or Tabletop, Wall Mounting Horizontally or Vertically, 8.5 x 12 Wall Gallery Poster Photo Frame with Shatter Resistant Plexiglass, Gold
controller board which is compatible with the matte 60hz and the non touch 2.8k display
Amazon.com: Beuiouer DP to EDP 4K 120HZ DIY4K Driver Board 4K 2K 1080 Adapter Board for Portable Display(A) Easy Install : Electronics
40 pin to 40 pin cable
Amazon.com: VSDISPLAY 40Pin Signal Cable for eDP LCD Screen,Fit for 4K Panel : Electronics
You do have to remove the retaining clips from the display for it to fit in the picture frame.
