Does anybody knows if wifi card AX201NGW is compatible with my AMD Framework 13?
I have that wifi card from an old laptop and I was wondering if anyone has experience with that one
Linux mint
Which release version? 22
Which kernel are you using?
6.8.0
03.05
7040
No, that card is not compatible. The AX201 uses CNVio2 which is Intel-specific and proprietary. They moved some of the hardware off the wifi card and onto CPU/chipset in order to make their wifi cards cheaper. Personally I think its dumb since wifi cards are already quite cheap, so I always avoid CNVio2 cards like the plague. The version of that card without Intel’s proprietary bullshit is the AX200.
thank you so much, I didn’t know there were intel specific wifi cards.
The AX201 was used in prebuilt 11th gen systems. DIY systems got the AX210. I had an AX201 originally, but I broke one of the antenna connectors when I replaced the top cover with the CNC version so I had to buy an AX210 to replace it; I’m still using that with my new HX 370 mainboard.
so you mean that it works with an AMD processor?
AX201 will not work. AX210 works (I’m using it instead of a stock RZ616 card that comes with AMD 7040 variant of Framework 13).
