Hello there, I just upgraded my 11th gen Intel board to i7-1370P, in otherwise fully working system, running Linux Mint. After booting up the system, I realized my Wifi is not working. In lshw I see only:
# lshw | grep AX
product: AX201 Bluetooth
I double checked if my wifi module is connected correctly and I don’t see any problem here. So the question is, is there any reason why AX201 module should NOT work with i7-1370P board?
The AX201 isn’t supported as it uses a proprietary cnvio2 interface. Framework only supports M.2 PCIe wifi cards. You will need to use a AX200 or AX210 for wifi & bluetooth to work correctly.
Framework sells the AX211, which as I understand it also uses intel’s proprietary CNVio2 interface. It’s just not supported on 11th gen mainboards. Not clear if it may work on the 13th gen.
