Expansion Card Carrying Case
That’s pretty neat! I wonder how bulky that feels…
Right now I use … well, just a regular mesh bag I got at an outdoors store:
It’s kind of a mess to be honest. Yes, everything fits in there (and I hope to fit a travel charger in there as well, the weird-o TOFU Power Station (MARU) - Traveller Bundle), but you can’t find stuff in there easily. Typically, I need to empty the pouch to find the right expansion card, so having a thing where all the cards are visible and in a predictable place sounds like a brilliant idea.
Got this back in 2018 and it fits pretty good!
UGREEN_FW_CARDS|281x500
Cool! Also, I love your username!
Hi, new to Framework and loving my FW16. I bought more expansion bay modules than I plan to keep installed in my machine depending on needs (drive, sd reader, hdmi). Has anyone found a nice storage case that works well for organizing them instead of letting them float around loose in a backpack pocket?
Thanks, I did that and I think my connection must have been crap because nothing loaded.
I tried a few of the 3D printable ones posted around the forums and settled on this one as my favorite:
This is perfect, like a little cassette case I love it. Definitely gonna try to print this.
wait
nonono does it … gasp
It FiTs In GrIdFiNiTy
is slightly too tall, but with reduced material base should fit
Obviously I won’t call it like that; will CAD up something so they can be kepy more snugly in
