Hello I am wondering what you guys use as containers for expansion cards that you would throw into backpack? also I don’t own a 3d print so I can’t print one out
I find that the SD card pockets in my Peak Design Tech Pouch fit expansion cards perfectly, and since that’s already always in my bag, thats where I keep them.
Take a look at https://craftcloud3d.com/ to 3D print files and have them shipped to you. As far as models go, take a look around online and this forum. If you don’t like any of them, you can design them, or let me know and I’ll give it a go as it’s something I’d have a use for as well.
If you don’t have a lot of extra cards you need to carry around, it was found out a while back that cases for CFExpress/XQD cards pretty much almost fit expansion cards, so if they have foam on the inside like this one you can squeeze in expansion cards (unfortunately all the ones I have found that are made to hold 6 cards don’t have enough height to hold more than 3 Framework cards.
