Which OS (Operating System)?
Not installed yet, haven’t done first boot
Which Framework laptop (11th, 12th or 13th generation Framework laptop, Chromebook or Framework Laptop 16) are you asking for support with?
FW Laptop AMD Ryzen™ 5 7640U - 2.8k Display
Just want to know if the extreme heat and fans turning on is normal for the first boot up…
If the machine is set to turbo boost or something like that in the bios for startup then yes it is. It means that the system is at full tilt to allow the system to boot faster. It is not expecting to sit in the BIOS for a time. This could be improved, because the system just gets hot for no real need.
With this feature set to max battery savings, the fans will not come on assuming the system is cold. But this does slow down boot performance.
