Hello everyone,
my Framework 13 AMD with an 7640u is overheating when i play some games. The last game I played was Need for Speed Most Wanted the version of 2005.
The same happend with Minecraft and Grim Dawn.
OS: Windows 11 with the latest Updates.
SSD: WD-Black-770 1TB
RAM: Crucial RAM 32GB Kit (2x16GB) DDR5 5600MHz CT2K16G56C46S5
HW-Info show that after the reboot the max-temp of the CPU was 96°C and the rest of the system was between 50°C and 70°C.
The laptop stands on an laptop-stand so the airflow should not be a problem.
Are there other users with similar problems?
Maby its an hardware manufracture problem or a software problem. Because when hardware got to hot it should reduce the powerconsumption to reduce the heat. But that didn’t work as far i can say.
