Fan mount screws
Hello!
Can anyone help me with screw dimensions required to mount a normal, 25mm-thick fan (this one) to the Desktop Motherboard? According to FW Support, the motherboard comes with Schroedinger screws that both are and are not compatible, depending on which reply I read.
Hey
On Framework’s guide they mention 27,3mm length.
I guess this includes the thickness of the fan duct, so if you are not using one maybe you should subtract a few millimeters.
As for the head’s diameter, maybe something like 6 or 7 mm, or more.
Hope I could help.
I finally did get a reply that confirms the included screws will work for a standard fan.
Nice !
