I thought it would be useful to start a topic for those who purchased just the motherboard, as there are some considerations when putting together a system.
First, as stated in the order page, the bare board doesn’t ship with a fan, but it does have a fan shroud. Not quite sure what the use is (it mounts on top of the fan), unless it is to direct airflow when the board is in a case (i.e., the shroud forms a seal with the case). Also, the low profile fans available mostly don’t have the CFM or static pressure that Framework recommends, the fans they ship with the full desktop have been customized for them by the manufactures (according to a Framework blog post).
So I ended up ordering a thicker (30 mm) fan that does have the correct CFM and static pressure (Corsair RS120 max). But the screws it shipped with are 1mm thread pitch, whereas the heat sink takes .5mm thread pitch screws. The screws shipped with the fan shroud will hold the fan on, but not if you include the shroud. So I ordered a package of M3x30 .5mm screws off Amazon. Will have to 3d print a shroud for the screws as the ones shipped by Framework (and the ones that come with the fan) have a long shank that is 4mm thick, with a few mm of threads exposed at the tip of the screw. For right now I have the fan mounted without the shroud, as I’m using the MB outside of a case while setting it up. (Is the fan shroud only needed with the low profile fans?)
I have a leftover 500 watt full size ATX power supply that I’m using, seems to be working ok so far.
I’m using a Samsung 990 EVO SSD, installed Fedora 42, installed LM Studio, downloaded the gpt-oss 120G model, and have had really good success (19.8 tokens/sec on my initial tests). Will need to set up my other models, and start playing around more.
Next, I need to 3d print the case I want (the main reason I went bare board, is I want to put in a SATA adapter, either via PCI slot or on one of the nvme slots, and add in my 20 TB drives if I need too). The case I’m designing will have the full sized ATX power supply on the bottom, the MB mounted vertically with components to the left, and there will be room on the right side for 3.5 inch drive cage(s).
So summary of what is needed with a bare MB:
- Fan that hits the required CFM and static pressure
- m3x30 .5mm pitch screws, with a 4mm thick shaft for the bulk of the screw, or a sleeve that can be 3d printed
- appropriately fast SSD (nothing like slow model loading to make for a bad experience)
- Whatever case solution.
- Adapter cable for the front two USB ports, to pull them to either USB C or USB A sockets (I haven’t touched on this yet, but will research that after and update this post as needed).
- Bare board doesn’t ship with WIFI, so if you want that purchase that separately.
- Oh, one more thing – a t5 torx screw driver for the SSD screw – the bare board of course doesn’t ship with the Framework tool.
Anyone have anything else to add?
