I recently upgraded my mainboard from the 11th gen to a 12th gen processor and my fan noise has noticeable increased to the point where the laptop is unusable in meeting environments. Is there a way to adjust the fan curve? Tasks are standard productivity and browsing. CPU load is around 15% and memory at 44%.
Temps on HWMonitor don’t exceed 64-72 degrees, but the fan is always running.
Any help is appreciated!
I installed “Fan Control” on my Framework running Windows 11. I have it on Auto and it does a great job of taming the current “Digital” fan control curves of the 12th gen.
I’ve used Fan Control before on other laptops and I agree it works very well!!
@Eric_Crawford-Anton Can you share how did you configured Fan Control? I have downloaded but beside monitoring temp I cannot control the fans…
Thanks!
It was the first time I used it and it was a little confusing as well for me.
After creating your fan profile (I just used the Auto Beta profile), click on the 3 Dots in the upper right-hand corner, then from what I remember “Load the configuration” That should save it to your system config file.
And Welcome to the community!!
The fan noise was very significant particularly as Win 11 opens from shut down for me (USB-C dock connected with two monitors). I carried out the following changes to set turbo boost to ‘Efficient Aggresive’ (didn’t disable completely) and I’ve not heard the fan since. Reddit - Dive into anything
