Fan Noise is constant and loud at 15% load
Hey everyone,
Been having this issue with my FWK13 i5 1240P. It started a year or so after purchase and has only gotten worse. Since support hasn’t been exactly helpful (in more than a dozen emails exchanged, the only solution offered has been to remove dust, which doesn’t help), I’ve perused the forums and this thread seems to most accurately fit my problem.
@Max_Klassen are you still happy with your improved mod? If so, I’d really appreciate it if you (or someone else) could help me idiot-proof this! I understand I will need to follow this Framework guide to get the heatsink/fan out, but I’m confused.. This will be my first time doing a mod like this (I’ve only ever replaced batteries). Some questions I have:
  1. Am I supposed to follow the Framework guide up to step 8 (but not including step 8) and then use the first four pictures in your original post to decide what goes and what stays?
  2. In your improved mod, do you still have thermal pads remaining on your heatsink? Are there still some pads remaining as shown in your original post, or is it just the layering of (in chronological order) MX-4 paste and K5-Pro paste applied to the area shown above?
  3. From the way it’s phrased, I can’t tell whether the left part of your image shows a triple-combo of MX-4, K5-Pro and PTM, or if the PTM is only used on the CPU (that’s what it looks like on the picture to me).
(Feeling somewhat stupid right now, to be honest. )
This might be too much to ask, but if you could (instead of answering these questions) explain your new mod like you did your old one, step by step, I think I’d feel more capable in giving this a try. Otherwise, I might just waste the components (and possibly mess up my laptop). And then we can try to get Framework Support to recommend this guide to people having this issue.
