I have an 11th gen laptop with an i5-1135G7 running Windows 10, version 2004, build 19041.1415.
Recently the fans started misbehaving. They will pingpong between completely inaudible and as loud as I have ever heard them, at seemingly random intervals, regardless of what the laptop is doing. They even continue doing this while the laptop is put to sleep, the lid is closed, and the whole case is cold to the touch. This behavior persists past a system restart.
I looked at the CPU temps using Core Temp and they seemed normal, hovering around 40C when I checked. Other than that I’m not sure how to find more information about what could be going on.
What can I do to diagnose and try to fix this issue?
This started happening to my laptop this past week (1165g7). As of this writing I just turned on my laptop on after it was off for several hours(completely room temp machine). The fan is running at 100%, but it’s also randomly turning off for random amounts of time.
When I typed these commands in the fan was running full speed, but the EC says it’s not.
$ sudo ./ectool temps all
--sensor name -------- temperature -------- fan speed --
F75303_Local 299 K (= 26 C) 0%
F75303_CPU 300 K (= 27 C) 0%
F75303_DDR 299 K (= 26 C) 0%
Battery 297 K (= 24 C) 0%
PECI 303 K (= 30 C) 0%
$ sudo ./ectool pwmgetfanrpm all
Fan 0 RPM: 0
$ sudo ./ectool thermalget
sensor warn high halt fan_off fan_max name
0 0 361 371 313 335 F75303_Local
1 0 361 371 313 342 F75303_CPU
2 0 360 370 313 335 F75303_DDR
3 0 323 333 313 323 Battery
4 368 376 378 377 378 PECI
EC result 3 (INVALID_PARAM)
(all temps in degrees Kelvin)
