Fan speed reporting
Has anyone figured out how to enable fan speed reporting with lm-sensors?
I’m on Pop!_OS 21.04, maybe I need an updated lib or something.
Can you read framework laptop speed fan with Hardware Monitor on Windows? Fedora 35?
negative on F 35 :frowning:
Which BIOS version are you on?
I’ll try to find someone on Windows. I’m using 3.03 as the beta only listed changes related to the realtek chip change. I’m not even sure there is a fan speed sensor on the board.
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +46.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +42.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +46.0°C  (high = +100.0°C, crit = +100.0°C)
Core 2:        +42.0°C  (high = +100.0°C, crit = +100.0°C)
Core 3:        +45.0°C  (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
Adapter: ACPI interface
in0:          17.35 V
curr1:         0.00 A
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1:        +32.0°C
nvme-pci-0100
Adapter: PCI adapter
Composite:    +38.9°C  (low  =  -5.2°C, high = +83.8°C)
                       (crit = +87.8°C)
acpitz-acpi-0
temp1:        +46.8°C  (crit = +210.0°C)
Opened up HWMonitor on Windows 10, BIOS version 3.02.
No fan speed reported, so I doubt there’s a sensor for it.
