Hi Kenny,
thank you for your reply. When I run sensors-detect I get the following:
# sensors-detect version 3.6.0
# System: Framework Laptop (13th Gen Intel Core) [A7] (laptop)
# Board: Framework FRANMCCP07
# Kernel: 6.8.0-62-generic x86_64
# Processor: 13th Gen Intel(R) Core(TM) i7-1370P (6/186/2)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... No
AMD Family 15h thermal sensors... No
AMD Family 16h thermal sensors... No
AMD Family 17h thermal sensors... No
AMD Family 15h power sensors... No
AMD Family 16h power sensors... No
Hygon Family 18h thermal sensors... No
Intel digital thermal sensor... Success!
(driver `coretemp')
Intel AMB FB-DIMM thermal sensor... No
Intel 5500/5520/X58 thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): yes
/dev/port: Operation not permitted
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): yes
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): yes
Found unknown SMBus adapter 8086:51a3 at 0000:00:1f.4.
Sorry, no supported PCI bus adapters found.
Next adapter: i915 gmbus dpa (i2c-0)
Do you want to scan it? (yes/NO/selectively): yes
Next adapter: i915 gmbus dpb (i2c-1)
Next adapter: i915 gmbus dpc (i2c-2)
Next adapter: i915 gmbus tc1 (i2c-3)
Next adapter: i915 gmbus tc2 (i2c-4)
Next adapter: i915 gmbus tc3 (i2c-5)
Next adapter: i915 gmbus tc4 (i2c-6)
Next adapter: i915 gmbus tc5 (i2c-7)
Next adapter: i915 gmbus tc6 (i2c-8)
Next adapter: AUX USBC1/DDI TC1/PHY TC1 (i2c-9)
Next adapter: AUX USBC2/DDI TC2/PHY TC2 (i2c-10)
Next adapter: AUX USBC3/DDI TC3/PHY TC3 (i2c-11)
Next adapter: AUX USBC4/DDI TC4/PHY TC4 (i2c-12)
Next adapter: SMBus I801 adapter at efa0 (i2c-13)
Do you want to scan it? (YES/no/selectively): yes
Client found at address 0x50
Handled by driver `ee1004' (already loaded), chip type `ee1004'
(note: this is probably NOT a sensor chip!)
Client found at address 0x52
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Next adapter: Synopsys DesignWare I2C adapter (i2c-14)
Adapter doesn't support all probing functions.
Some addresses won't be probed.
Next adapter: Synopsys DesignWare I2C adapter (i2c-15)
Client at address 0x50 can not be probed - unload all client drivers first!
Next adapter: Synopsys DesignWare I2C adapter (i2c-16)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
* Chip `Intel digital thermal sensor' (confidence: 9)
To load everything that is needed, add this to /etc/modules:
#----cut here----
# Chip drivers
coretemp
#----cut here----
If you have some drivers built into your kernel, the list above will
contain too many modules. Skip the appropriate ones!
Do you want to add these lines automatically to /etc/modules? (yes/NO)yes
Successful!
Monitoring programs won't work until the needed modules are
loaded. You may want to run '/etc/init.d/kmod start'
to load them.
Unloading cpuid... OK
and subsequently running sensors I then get
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: N/A
nvme-pci-0100
Adapter: PCI adapter
Composite: +36.9°C (low = -5.2°C, high = +89.8°C)
(crit = +93.8°C)
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +49.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +42.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +41.0°C (high = +100.0°C, crit = +100.0°C)
Core 8: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 12: +41.0°C (high = +100.0°C, crit = +100.0°C)
Core 16: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 20: +39.0°C (high = +100.0°C, crit = +100.0°C)
Core 24: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 25: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 26: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 27: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 28: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 29: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 30: +48.0°C (high = +100.0°C, crit = +100.0°C)
Core 31: +48.0°C (high = +100.0°C, crit = +100.0°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1: +49.8°C
temp2: +45.8°C
temp3: +48.8°C
temp4: +41.8°C
temp5: +0.0°C
so I can see the board has picked up various thermal sensors on and around the CPU but I haven’t seen anything indicating a fan so based on that, I wonder if the part of the motherboard which controls the fan is no longer working.
When the computer is off, so is the fan, but when it is on whether it is suspended or not, the fan runs at a single speed.
