Had to take off my heatsink while talking to support, this is what I found from the factory.
FW13 7840 Batch 8
After a couple of years of use, I noticed my FW13 having thermal issues. Reapplying thermal paste really seemed to help with that. I think the factory stuff is okay, but eventually it dries out a bit and becomes less effective.
That looks a mess ~ like some ‘contacts’ have been engulfed by liquid metal ??
The FW 13 doesn’t use liquid metal. That’s just standard thermal paste.
Yes I got that but it looks like it’s spread so much
Might also be pump-out which also probably caused the thermal issues in the first place.
Spilled liquid metal would look a lot worse XD
Where did you find the batch number, I can’t find mine in the orders page
Are you referring to it being thicker at the top, or looking slightly liquid at the bottom? I can’t really tell. Apart from that, it looks pretty okay to me.
