Fingerprint sensor says update to 1000334 when 01000334 installed
Clicking on “update to latest” says ‘Failed to Install Firmware. Installed same Firmware version.’ I make it that the leading zero is missing from the firmware version somewhere. Annoying to be nagged to update when the firmware is up to date.
The fingerprint sensor is unreliable, but that is discussed in other threads.
Yea, I’m also getting an issue with this update
~/ > fwupdmgr update
║ Upgrade Fingerprint Sensor from 01000334 to 1000330?                         ║
║ LVFS release to allow native Linux update from the factory firmware.         ║
║ Fingerprint Sensor and all connected devices may not be usable while         ║
║ updating.        ║
Perform operation? [Y|n]: Y
Decompressing…           [***************************************]
(fwupdmgr:481707): FuMain-WARNING **: 11:57:42.662: No reports require uploading
Specified firmware is older than installed ‘01000330 < 01000334’
Seems to be a mislabelled version number on the face of it.
I attempted to install it with “fwupdmgr install $DEVICEID 1000334” and while that seemed to work, after the install it was still showing as the same version 01000334 so I can’t confirm if it actually updated.
edit- Looking at the previous release of 01000334 from April 2024 it is showing the same patch notes and release ID. Definitely something buggy going on.
have the same issue, following.
My attempt to install failed with a ‘already current’ error. I tried both using firmware updater and command line with the same outcome.
As of today this seems to have resolved itself for me.
