Firmware Update error
Which Linux distro are you using? Fedora Workstation
Which release version? 43
Which kernel are you using? Linux 6.19.11-200.fc43.x86_64
Which BIOS version are you using? 3.19
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) 12th Gen Intel® Core™
Software is prompting me to update the firmware for the fingerprint reader, but when I actually try to do it, it says the latest version is already installed.
Message reads:
Unable to download updates
Specified firmware is already installed ‘0.1000334’
I’m also seeing the same problem on the Framework 16 on Fedora 43. I wonder if it is because the file names are being seen as the same since one starts with a zero, and the zero is being ignored.
