For future consideration - no speakers for more battery
In the delightful process of putting the bits and bobs in my Framework 16, I had a notion. I would love for when I need to swap out the battery that I could remove the speakers and use that space for more battery. From what I could tell, this would be very doable looking at the space. I would only use headphones and this seems like a very easy way to get more battery.
I have no idea what it takes to get a new battery made from the manufacturing and design point of view. I figure in a few years when I get the second video card upgrade (or buy a used one when the second one comes out) that this would be a great time for that.
Apology if this came up before and my searches did not fine that post.
If there has ever been a laptop in a position to make this possible, it’s the Framework.
The annoying thing about 10 billion people on the same planet is, that every idea has already been had :sweat_smile:
Thanks for the links. I knew I couldn’t have been the first one. I’m the derp who didn’t check the forums for the 13 before posting.
