Framework 13 (AMD Ryzen 5) – Display shows vertical lines and distortion
Hi everyone,
I’m using a Framework 13 (AMD Ryzen 5) laptop and recently started having issues with the internal display. I’ve attached a picture (and can also share a short video) to show the problem.
Symptoms:
  • The screen shows vertical colored lines and distortions.
  • The issue is limited to a certain area of the display.
  • When I apply light pressure to the bottom edge of the screen, the lines change or sometimes partially disappear.
  • External monitors work fine, so the GPU/mainboard seems unaffected.
Questions:
  1. Does this look more like a faulty eDP cable/connection, or a damaged LCD panel?
  2. Would it make sense to try reseating or replacing the display cable first, or should I go straight for a display module replacement?
  3. Any troubleshooting tips before I reach out directly to Framework Support?
The laptop is still fairly new, so I’m also considering filing a support request if this points to a defective panel.
Thanks in advance for your advice and experience!
Atleast check the connection cables because that is the first question that support is going to ask you to do anyway :slight_smile:
Hi @Daniel_Six Please shoot a message to our support. We’ll get it taken care of for you.
