Framework 13 Cooler Master case & WiFi
I’m converting my Framework 13 Gen 1 to an HTPC with the Cooler Master case. Do I need an antenna for the WiFi module? It doesn’t look like I can easily remove the antenna from the base of the display.
I would think so, I am about to convert mine and will just be using Ethernet. You can get pretty cheap ones online if you can’t get it out or if it breaks.
