Framework 13 Pro - Debian Wifi Drivers
Debian 13
Which release version?
Latest Stable
Which kernel are you using?
Latest Stable
3.02
FW 13 Pro Intel Ultra Series 3 X7,
Hello! I just got my FW 13 Pro, Batch 10.
I am working on getting debian installed as my daily driver operating system.
When I go through the install process, however, it tells me it’s missing drivers for the wifi card. It lets me provide them, but I don’t know where to get these. All I could find were the windows Wifi Drivers.
Any help would be appreciated.
This has been discussed recently in FW 13 Pro batch 10 guild: https://community.frame.work/t/fw13-pro-batch-10-guild
Refer to kbhasi on message # 51 and see if that helps.
