Framework 13 Pro Suddenly Not Turning On
Ooh! I retract my comment. What country are you in? I did not get that as an option in the UK.
I think that was something that Framework has added fairly recently is the ability to purchase a longer warranty coverage for both consumers and business users. It was one of the more requested features to be added to their product lineup.
I’ve found Framework Support is still good about trying to get your laptop working, even if it’s outside the warranty window. You may need to buy a new mainboard or something, but (unlike most other laptop manufacturers) the chances of needing to buy an entirely new computer are pretty low.
Even with the 1 year warranty, and even after having two mainboards die on me (one under warranty, replaced by Framework, and one out of warranty, upgraded by me), I think Framework stuff is generally up for the long haul.
Jesus that capacitor got absolutely annihilated.
FYI, I discovered from Support last week that extended consumer warranties are only available in the US. Hopefully they will roll that out to more countries in the future.
Ceramic capacitors can become little fireballs if there is sufficient power supplied to them.
I had a situation with a minicomputer a couple of decades ago. We had the machine doing some burn in testing as it had just been delivered and we had pushed the memory to maximum capacity. I got a service call that said the machine was “on fire” and had been turned off. I rolled up to find a ceramic capacitor on the memory board had decided to fail and burnt a hole in the fibreglass PCB a good inch (25mm) in diameter. The reason it was able to do this was the power supply was a 5V 300A switched mode supply, and there was very little load on it, so when the capacitor failed and demanded more current the power supply response was ‘how much would you like, I’ll give all that is available’. The result was a little pyro capacitor that burnt a heap of epoxy fibreglass causing the issuance of much smoke and smell.
This one apparently stayed alive long enough to do significant damage to the underlying board.
Well, if it was efffectively across the battery then there is the possibility of quite high currents limited only by trace resistance and battery internal resistance, so once a capacitor becomes a little resistor anything can happen.
That part is clear, the thing staying conductive and not in plasma form for long enough to dig a hole this big is the impressive but I suppose ceramic is supposed to be pretty temperature resistant XD
Reading that Warp factor 9 power excursion you described made me chuckle.
“She can’t take much more of this captain” -Scotty :high_voltage::fire::sparkler::phoenix::fire_engine:
