Hello everyone! Does anyone have the background image for the new framework 16-inch laptop?
Thank you so much I have tried to look it up on the web but I could not find any but one with a green background. Thank you so much!
someone on reddit made a bunch of derivatives of the original one
Thank you again so much I love this background
Hi everyone…I just got my FW 16 and really wanted this background so I worked on and edited the original(from twitter) as best I could to make as close to the original as possible and wanted to share it here with everyone.
I also made other versions for different resolutions (Including the FW13), transparent for any background color, as well as a greyscale version. They all should be easy to color however you see fit, I made sure to remove all dithering/pixelation around lines…you could edit this in MS Paint if u want to! Also included an SVG file for scalability but some of the finer detail is lost from the conversion.
I linked the .zip below…enjoy!!
FW_Wallpaper
*Edited the link to add 6 colors based on FW Bezels
Hey there. Nice work! Do you have a 3:2 version of this for fw13? There’s only a black color for fw13 in your zip file.
That one should have a transparent background…that way you can add any custom color in MS Paint or other editors
