Framework 16 needs a Brighter display
I’d really like a brighter display for the Framework 16. Despite the fact that the display has 100% DCI-P3 coverage, the colors feel washed out when touching grass. From my limited experience working with computer Graphics, I do know that brightness and contrast go hand in hand with color perception. I think a 1000 nit panel would be a killer feature (even if it eats through the battery). I have no idea how feasible this is given that Framework is a smaller company and the display does need to fit with the existing design (more or less).
Edit:
I did some googling and here is some of the relevant color theory:
Steven’s Effect ( DOI:10.1364/JOSAA.24.002766) [Couldn’t find a Wikipedia Article about this]
Hunt Effect (Hunt effect (color) - Wikipedia)
Color Adjustment Model (Color appearance model - Wikipedia)
Hi, Parth,
Can you elaborate on what “colors feel washed out when touching grass” (emphasis added) means?
–Dave
probably meant outside view.
I think 500 nits is fine. Ironically, if you can find a 4-lane eDP screen, its most likely a drop-in replacement. Get someone to make cable for you, easy.
Ironically, i want a DIMMER display. even at minimum it can be a bit too bright. And this is before you turn off the lights.
I was talking about color perception in high brightness environments (like the outdoors).
I think more range on the brightness is advantageous to improving viewing in a wider array of environments.
I’d also love to see a transreflective display that actually uses less battery and becomes easier to read in the daylight. Those are cool.
People with the original GBA start having war flashbacks
From the display manufacturer, you can play around with the PWM of the backlight. A lot of them specify 10% as minimum, but a lot of manufacturers let you go down to 5% or 2%. The circuit is not super stable at low PWM values, so your display might have a slight flicker,
I should read the thing. I have the stolen sheet, after all.
This was actually infamous. If you ask GPT what uses NE160QDM-NZ6, it will tell you Framework
