Framework 16 touchpad getting stuck in the clicked position
I have a Framework 16 that I got about a month and a half ago, and since a few weeks ago, I’m having a very annoying recurring issue where the touchpad sometimes gets stuck down in the “clicked” position. I can usually persuade it to unstick by putting some pressure on the bottom part of the touchpad, but it seems like after it happens once, it’s pretty likely to happen again before long. If I unseat the touchpad and click/unclick it a few times, then put it back in, that seems to at least buy some time before it starts sticking again.
Has anyone else experienced this? Did I just get a defective touchpad?
I have not experienced this issue yet on my Framework 16, so I would recommend contacting support and seeing if they have any solutions to your issue.
If there are no solutions found, you should be able to get a replacement if you’re still under warranty.
Thanks, yeah I’ll reach out to them.
