Framework can´t find a boot device (first start)
Hey!
Finally i got all my parts together and tried to start my framework. Unfortunately it won´t recognize my bootstick (win 10). There shouldn´t be a problem with the stick, i borrowed it from my company which uses it all the time and i just used it on another laptop where it worked too. I also tried different ports so i don´t think theres te problem either :confused:
Does someone know a way to help me? Thanks :v:
Do you need to set the bios to boot from the correct port?
Paul
Do you have Secure Boot enabled? Unless this install image was built from official Windows media, it might not boot with secure boot turned on.
(Furthermore: if you do successfully install Windows with it and Windows doesn’t boot with Secure Boot turned on, you have a compromised system.)
How do i do that? As i´ve mentioned i tried multiple ports (aka switched my usb-a module around) but not all of them.
Secure boot is enabled & it was built using official windows media. We already installed Windows on some Dell Laptops with that stick and it worked without any problems.
